Whens the next scoop shootout? |
Post Reply | Page <1234 5> |
Author | ||||
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Right thats the banter on how it should be done, now lets have the banter of what driver/scoop combinations should be there??
YoungBlood
Registered User Joined: 10 November 2007 Location: London/Jamaica Status: Offline Points: 442 |
respecks nitz as long as turbomax get enough power and eq to blast no problem... Edited by YoungBlood - 15 January 2011 at 9:38pm |
"chyll wynstan.."
Nitz V1505
Old Croc Joined: 16 September 2009 Location: UXBRIDGE Status: Offline Points: 1719 |
True that but I do like the sound of the xb inna scoop. For me its not all about brutal spl its about what sounds the best. But for a shoot out you gotta take the driver within an inch of its life!!!!!! |
& THE TOPS LIKE LIGHTNING..... |
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
Edited by mykey- - 16 January 2011 at 4:00am |
mykey-
I would say test like this...... 1. first put into categories 15? 18? 21" mini-full 2. Test all flat 3. Sweeps 4. Test at full power (youngblood) 5. Test at designers preference (youngblood) 6.. Best in each category 7. Test with all genres of music 8. Best all round scoop of the day, taking into account, weight, size, sound should take a few hours |
PauliePaul
Young Croc Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1485 |
So, Sir, will you be bringing your own drivers (TM's/PD.1850's or whatever) to be hammered to within an inch of their life and/or nailed to a cross in the name of 'proper soundman' testing.... or will you be expecting other people to bring their lambs to the slaughter whilst you watch and criticize from the back?
Perhaps consider calibrated tone generators and measuring devices and a single amp set at a specified level to ascertain spl levels at different frequencies and to get a feel of what the boxes can do.... ie, at xHz box A and driver A produced ydB, but with box A and driver B it produced zdB...... instead of throwing some badly copied/burnt/over eq'd track through someones system which will be set specifically to what they run or use.
Do some higher power track testing later after all the measurements have been taken to see how the aural results compare to the tone results.
Incidently, if you have to throw bucketfulls of power at a cab/driver combo to produce a similar sort of sound level to that of another cab/driver combo using much less power then that itself should speak volumes to you. (Note: I didn't use the the phrase 'quality of sound' in this paragraph, only sound level)
Classic!
TONY.A.S.S.
Before listening to any music, you could run a sweep test at 5hz intervals into all the cabs through the same amp. Make up the graphs accordingly. This will tell you loads before you start.
I do this with all A/B testing i've done in the past. Paul and I also did this in the factory between two different chassis speakers. It would be a very good start and completely fair.
S&P
Registered User Joined: 01 March 2008 Status: Offline Points: 222 |
So is there going to be one then? Anyone chomping at the bit to organise it?
Sounds and Pressure Lo Fi Sound - Ska, Rocksteady, Reggae
http://www.facebook.com/events/412323448834558/432237103509859/?comment_id=432362186830684¬if_t=event_mall_reply#!/groups/75371249167/ |
mykey-
5hz steps do you mean Tony? or do these intervals involve cups of tea and biscuits? if so, I'm defo coming
Edited by mykey- - 19 January 2011 at 7:36am |
Nitz V1505
dansound
Registered User Joined: 29 November 2004 Status: Offline Points: 330 |
if no venue is sorted for this yet, i maybe able to host it in north london quite soon. who's in.
PEACE//LIVE IN IT//OR REST IN IT
mykey-
Danny boy, yu the man, Tottenham?
