Where could I find this PSU? |
alphabetikal
Registered User Joined: 20 May 2010 Location: UK Status: Offline Points: 217 |
Posted: 29 November 2013 at 4:25pm |
HI everyone
wondered if someone here could help with PSU knowledge I need to find a PSU which can supply 45w, 12v and about 3.95A. Its for a blackmagic multibridge pro video capture device. It needs to have a 6mm x 2mm(centre hole) jack (this is what tech support told me) I dont want to buy the official one for £55 - too pricey (got the kit for peanuts even tho it cost lots new) Could I use a toshiba laptop powersupply like this? This one says 19v / 75w ...assuming it will fry it? Thanks A
Earplug
Plenty of suitable power supplies out there:
http://www.ebay.com/sch/i.html?_trksid=p3984.m570.l1311.R1.TR10.TRC2.A0.X12v+4a&_nkw=12v+4a+power+supply&_sacat=0&_from=R40 Just be carefull with the polarity. |
lutkeveld
If you want 12v you should look at 12v psu's, not 19v ;)
Be sure not to take a really cheap one as it may damage your stuff.
kedwardsleisure
Maplin do a nice multi voltage laptop-style psu with a selection of 'ends'. Surprisingly they're a competitive price.
North Staffordshire |
mini-mad
http://www.ebay.co.uk/itm/12V-5A-3A-4A-FOR-TFT-LCD-TV-Monitor-Adapter-Charger-Power-Supply-5-5mm-2-5mm-A-/400557127275?pt=UK_Computing_CablesConnectors_RL&hash=item5d4310b66b
one of these... cut the end off of it and wire your plugs end to it, getting the polarity rite, and jobs a good'un |
slaz
Common as muck at fleamarkets/bootfairs .... 4A capable ones a bit less so, but still not hard to find.
Usually supplied with small monitors/TVs. The connector will likely be 5.5mm outer with 2.1mm inner. Should be plentiful on ebay also ... |
slaz
alphabetikal
genius! thanks all.
gonna check old maplin does it matter if its 5A and not 4A? Does it mean the device just wont 'use' that extra 1A? Cheers :) a
mini-mad
it means its capable of 5A... even a 4A laptop PSU wont use the full 4A all the time
