  New Posts New Posts RSS Feed - where to start with dmx
thestagebus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thestagebus Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2013 at 3:13pm
Originally posted by James Tengo James Tengo wrote:
Yep, you can program "blind' if you know what values do what, check out manufacturers range tables for fixture attributes
No need to know what the values do from manuals in LimeLIGHT as it's software based, so all the information is on screen Smile Makes it quite a lot easier to program than having to look up values!
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2013 at 10:08pm
Originally posted by nuclearbass nuclearbass wrote:
heres the galactic moon
(pin 3 cold, pin 2 hot, pin 1 grounded) is that normal? or reversed?
That is reversed compared to the standard.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2013 at 10:53pm
The nightmare with the Galactic Moons is that the XLR connectors are soldered on to the direct onto the PCB so to change the polarity over would be a nightmare.
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2013 at 10:55pm
Surely I can make a cable myself?
one life - have fun!
Force fusion pro audio
Amplighting&sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2013 at 11:06pm
Yep a lead for this is easy to make but i found i had to put the dmx crossed lead and lights at the end of line rather then at the start as in run normal to crossed rather then crossed to normal if u get me
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2013 at 11:59pm
Sorry, I didn't make it clear what I actually meant! (long day!!!)
I meant that instead of having to have crossover leads and making sure they go in the right place if you have them all on the same polarity then you can use normal xlr cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2013 at 6:40am
I understood what you said, you also said the their a nightmare to change, so a cable seems like the simple option
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2013 at 11:41am
I've never had any issues using crossed fixtures anywhere in the chain, providing the remember to cross and uncross going into/coming out of them.
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2013 at 5:14pm
Ditto.
Just get the plug in polarity swappers, 2 quid from CPC. One in, one out. Also easy to see at a glance whether you've done it, as they would stick out about 2 inches further than a normal xlr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amplighting&sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2013 at 10:30pm
Cool cool many heads make easy work some good info on here do like a bit of lighting more so then sound
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2013 at 10:55pm
Watch out for the solid barrel type, the extra weight on the input / output socket can break the connector off the board if mistreated. Short jumper cables put less strain on the fixture, and make them in a easily spotted colour so they can be quickly checked as in. Lots of companies use yellow cable for crossed polarity convertors
