  New Posts New Posts RSS Feed - Which 12" Horn
Which 12" Horn
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Topic: Which 12" Horn
    Posted: 24 May 2007 at 5:40pm
Looking on building 2 horn loaded 12" tops for now. Will build another 2 later on when we get more bass end. Ive been thinking about the MT121. I will use SN12B's and some BM-D750's on the PH2723. They will be run actively. How low and high does the 12" section go? Will I be able to get close to 1.5K with the SN12B? I don't like the sound of 2" comps lower than that... They're gonna be used in a loud playback/DJ system. Its for bigger venues. We will still use our 15"+horn cabs for smaller venues.
The bass end a.t.m. is four T-18's. We like their sound and they get to the back of the halls we do. We will add another 4 as we get cash.
Or should I look at something like this?
Patrik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Patrik Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2007 at 11:23am
 ""How low and high does the 12" section go?""
mine drops off around 130hz. and start to roll off yest below 700hz.
they are loaded with the Neo from PD, 12MHZ or somthing.
