  New Posts New Posts RSS Feed - Which Driver HD 15 = 4 ohms
philip banyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Topic: Which Driver HD 15 = 4 ohms
    Posted: 28 October 2004 at 10:52am
Which driver should I use I have been strongly recommended on the
 P Audio BM15LF But do they do this in 8 ohms?
Other options but I am not sure about.
Fane 15xb  4 ohms is possible
PD 154? Ohms
PD 156? Ohms
Would the Pd 156 work it has 4.5-inch voice coil and 650 rms
So which is the best driver out of these for 2 bins HD 15
It must be 4 ohms not 8
Thanks for the efforts in reading this mail.
Kind of music is Ballroom dance music big Band sound.
PBanyer
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2004 at 6:09pm
Fane 15XB is nice in my reflex subs, but wont appreciate being in a horn.  Rog would call this a mush motor.
My first subs were 400W 15" Eminence units, and I specifically chose 4R units to get the most power out.  I've moved on from there.
I would recommend one of the 8R drivers, such as the P Audio above, or the C15 500LF.  You can the double up the units later, and still use the same amplifier if it is adequetely rated.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2005 at 6:35pm
Dunno how Rog can call that a mush motor as Fane 15XB has a BL of 27.35,QTS of 0.21, and xmax of 7.2mm,resonance at 37hz.
fernand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fernand Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2005 at 2:37am
Beyma speakers can be ordered with 4 Ohm. The 15LX60 might be a good candidate.
soundsystemdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2005 at 7:39pm
Check pro audio parts, they've got PD154 - the top recomendation for the HD15 in 4, 8, and 16 ohm.
Easy peasy.
But carfeul with those Fanes, there's a 15XB and a 15B-600, different Qts and BL and stuff.
Edited by soundsystemdan
