which is a better sub amp lab or crown |
Post Reply | Page 12> |
mashgwan
Young Croc Joined: 20 May 2004 Status: Offline Points: 613 |
Posted: 15 September 2017 at 10:25am |
hello which is a better sub amp to run 4 hog scoops
a labfp6400 with 2 x 2300 at 4 ohm (an older one) or a crown macrotech 5000i with 2 x 2500w at 4 ohm (a newer one) thanks nick
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
PKN XD4000 beats both of them on sub :-D
(if you like sound character free of distortion) |
cookie-dj
He didn't ask for PKN though Yawn |
You can't polish a turd!
U.Viktor
Yes but the Macrotech 5000i is a vastly undersized version of the 12000i, just like the 9000i therefore I would not recommend it.
The LabGruppen FP6400 is known for uploading 120A(peak) spikes to the mains network, effectively ruining other equipment connected to the opposite mains phases, this is the main reason it should be avoided. |
MarjanM
Old Croc Joined: 10 February 2005 Location: Macedonia Status: Online Points: 7816 |
Crown iTech 4000 beats PKN XE4000 badly on sub duty. So no, what you say is complete rubbish.
snowflake
Old Croc Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3121 |
iTech is a lot more money though.
mashgwan
or another amp around £1000 2nd would be good , but were limited on funds
need around 2500w on 4 ohm but the option to run 2 ohm aside to run 8 x es18's would also be useful |
MarjanM
Because the DSP. The amp part is same.
U.Viktor
Who knows the tricks happening really in a DSP pre-equipped amplifier?
When the signal is AD then processed then DA and AD converted again again + even DSP acts just bypass there are several changes on the signal. All these amplifiers have tricks built-in to make sonic performance "more comfortable" when you listening alone.. however these *features* are usually making them very bad when need to deploy in large scale. |
mini-mad
...heisenbergs amp!!! Changes it's sonic characteristics depending on how many people are observing the amp... Gotta get me one of those amps!! |
U.Viktor
Hehe :-) the dirty trick is that the DSP "sees" when test signal applied (such standard equal bust tone sweeps) provides flat frequency response.
If you apply music then tricks turned on. Normal test tools like SMAART or AP system 1 would not show the difference. All mayor three players doing this dirty. |
MarjanM
Who cares which trick they use? What maters is how they sound when you put them side by side.
