  New Posts New Posts RSS Feed - Which is best sounding driver in Super scooper?
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Topic: Which is best sounding driver in Super scooper?
    Posted: 01 January 2007 at 11:26am
Getting bit impatient waiting for ASS plans, so looking to experiment on Super Scooper.
Instead of hijacking some'ones thread, thought  I  would start this one.  This should really be a poll.
After reading plenty of older Posts, I guess it's out of the following,
1. P1850
2. Void V18-1000
3. PD186
4. Volt
Considering depth of bass and cost  also, not just SPL. Call me cheap, but realistically, I wouldn't consider any driver more expensive than PD1850.
Edited by levyte357 - 01 January 2007 at 11:26am
COWFOOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 11:36am
Isn't Void supposed to come out shortly with a dedicated scoop driver as per Rog's post?
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 12:01pm
Levyte: Look at Rog's thread titled "I've lost the plot" below in this same section.He doesn't consider the 1850 an ideal scoop driver because its vas is too low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 1:40pm
Looks like Rog is bringing out a new scoop box to complement the Void V18-1200 with some fancy " ... expanding chemical that sets like concrete".
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 1:57pm
Yeah, I read that.. Jolly interesting.. But I need something fairly soon, and I'm sure the new driver is gonna be mucho denaro...
I've heard lots about V18-1000/PD186 in scooper, so I guess I have to hear either them for myself. But I do know it is possible to get the right scoop/driver combo to play low enough without needing subs below them.
Sunil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sunil Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 2:03pm
shortmans scoop can go low enough so you dont need any subs below them. Just look at iration steppas!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 2:37pm
It's really mindblowing when you consider we have cutting edge developments happening here on Speakerplans.Wow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 2:56pm
Yup, heard that as well...
So all we gotta do is come up with slightly modified Superscooper tuned  lower for PD186/V18-1000 (larger rear chamber + extra throat thingy ?), and we have a public domain, Bad arse scoop bin.
I like the idea of being tuned  for choice of 2 different drivers, so driver shortage won't screw things up, like the last PD or FANE shortage.
Edited by levyte357 - 01 January 2007 at 3:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sunil Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 2:58pm
lol. Levyte, how does the superscooper sound as ive never heard it play? does it go low and does it tear down the place?
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 8:31pm
Those new prototype Fane drivers I heard and felt at the Rec certainlly came very close to PD1850.
And they are 1000w rms.
Might be worth waiting till those come out levyte357.
Except how did Mark Iration get hold of 10 of them if they are prototypes.Hmmmm, I thought prototypes would only be 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 01 January 2007 at 9:37pm
You can bet Fane has already done inhouse testing.Fane is streetwise.What better showcase for their new toys.Great grassroots move by Fane.
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2007 at 6:04am
1. P1850
2. Void V18-1000
3. PD186
4. Volt
Levyte, the Volt driver cannot fit in a standard super scooper.
The rear chamber in the scooper would have to be adjusted by some means.
The Volt RV4504 driver do not fit a super scooper built to the exact specifications.
The rear of the speaker hits the board in the rear chamber & the speaker itself protrudes forward nearly an inch.
Edited by Tekasis - 02 January 2007 at 6:28am
