Which OHM subs ??? BR or TRS |
Post Reply | Page <1 2345> |
Author | |||
mini-mad
please dont take offence.... were your trs218's copies?... i mean china will copy anything for a quick buck and so will anyone wanting to make a bit of ££££. did you buy them direct or "brand new" off someone you know?
any well made sub shouldnt rattle.... let alone 12 subs! it kinda sounds like someones pulled a fast one on you is all. sorry... iv got wine in front of me...
darkraver
Registered User Joined: 29 September 2009 Status: Offline Points: 143 |
Fail1 - abusing kit with excessive input level, if the cabs cant deliver whats needed at sensible level, the application needs more kit [HEADROOM!]
I totally agree. Trying to get more out of single unit by trying to put in more power does not make any sense. Best alternative would indeed be to increase the number of cabinets. That is why I think to try to put in 2,5kw is absurd ! Fail2 - replacing drivers with non originals. Driver TS parameters must be matched to the cabinets, power handling means didily squat if the sensitivity and response is all over the shop. You may find drivers which match, and also give a gain in sensitivity/excursion/handling, but you may find a different driver will have a terrible response all over the shop. Likewise, the driver could be hitting xmax or other mechanical limits through being badly twinned to the cabinet. Well I do agree again, you cannot just screw something differently in, just they have been in contact with 18Sound and some other Ohm users in advance who swapped speakers as well. Actually I have told them not to do it and spend the money on getting different subs, in fact I advised them to sell all TRS tops and subs but they decided differently. But anyway since then no more defects and the performance / sound did not get worse. And while doing a test sweep the drivers absolutely had a way better power handling ! The cabs are originals so no copies for sure :) |
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Darkraver - you don't say where in the world you are on your profile - but if you're anywhere remotely near Cheshire, it might be worth a trip to OHM to have a listen to a TRS that isn't one of 'those 12' - and if its logistically possible even take one of the 12 along to be looked at, really sounds like something's up.
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
Sorry, but you don't seem to know enough to challenge me on this one ;) Once again, please tell what settings were used in LMS and how did you do the "sweep test". |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Online Points: 4226 |
I have seen this problem before with TRS218 as we have had a lot of them come into us ex install either with blown drivers or lots of different ones that have been replaced by the venues.
The main problem is being overdriven by idiots who have no knowledge or no respect for equipment that they are using and we have also seen some really badly set up systems with either totally wrong settings in the DSP or very poor limiting. In a 2x18 sub such as Turbo or F1 the drivers rear chamber is a sealed small enclosure so they will take a lot more abuse than a ported horn loaded cabinet design such as the TRS218 and this is why the TRS218 design will give out more SPL, go down lower in response than the Turbo or F1 design and at the same time sound better, but to get the best out of them, they have to be set up correctly as any abuse or wrongly set up DSP units will result in blown drivers. Edited by Robbo - 21 December 2012 at 11:48am |
kristoffdj1
Registered User Joined: 24 December 2009 Status: Offline Points: 371 |
An I correct in thinking that a trs 118 is 'just' a single driver reflex box and a trs 218 is a twin driver ported horn?
darkraver
Pasi, I doubt to be honest. Settings are the original Ohm ones :) so nothing strange or weird. We discussed this a while ago already..
Edited by darkraver - 21 December 2012 at 12:54pm |
darkraver
I wrote a stack of 2 vs a single Ohm TRS
Pasi
Since i know what i'm doing, sure. Box is very underrated power handling wise anyway. Never blown a driver, not on these or anything else either. Just, list the settings here and we'll see. |
dylan-penguinmedia
The original OHM settings won't be much use now yours have 18sound drivers in, making them your own hybrid... |
darkraver
Pasi,
Luckily you are not the only person that has never blown any driver. I never did, but some people do. Especially DJs like red lights... And no I would not put any 2,5kw on a 800 or 1000W cabinet. Little mistake with processing and limiting and the party could be over before it has started.. Some while ago we played around with amps being tested on some 21" reflex ones. We managed to put in more than 4kw (or even 5kw, do not have details in front of me) into a listen 1600W AES 21" woofer. Does it make any sense.. Hell no, for that perhaps 1 db extra in my opinion is does not make any sense. |
darkraver
Well the 18S were purely installed to prevend damaged speakers. Nothing more, nothing less. |
