who's the xtro/punisher designer ? |
Post Reply | Page <12 |
Mark James
no he means the punisher, which is the bass cab to go with the xtro
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
Hi
I own the brand NEXTECH we redesigned the punisher / Xtro combo using P-audio components, and made some adjustmets to the designs. if you want to learn more about them, search for the "my version of the x-tro / punsher" topic over here they are professionally built and upgraded regarding components. Our Xtro now uses 2x15" + 2x8" + 1x2" (Custom versions include 4x1" drivers on adapters feeding a 2" horn) the Punisher is also modified the internal path has been smoothed to reduce noise , the backchamber modified and the outer shel is made from 18mm ply. And the woofer is the P-audio SD12 which has a 4.5" Voice coil. |
RichDigga
New Member Joined: 13 June 2011 Status: Offline Points: 6 |
The Beyma TD 245 has now been discontinued which is a problem. We have had 2 fully working xtros for ages but have just finished building another two which now we can't finish due to not being able to get hold of any TD 245s. Are there any other flares which would be a suitable replacement??? Blue Aran said the TD 164 is the closest match but would this affect the final sound, expecially if two cabs were with the 245 and two were with the 164?
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
http://forum.speakerplans.com/beyma-td245-discontinued-what-to-use-instead_topic59169.html read here this might help you |
