why 12mm on the baffle? |
keilamym
Joined: 20 November 2007 Location: California, USA Status: Offline Points: 443 |
Topic: why 12mm on the baffle?Posted: 22 November 2011 at 8:05pm |
hey guys, im just curious to know why baffle is made with 1/2 plywood while the rest of the speaker is 3/4 plywood... im doing a test build and completly forgot... atleast i hadn't installed them yet...
thanks in advance..
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 22 November 2011 at 8:16pm |
the original plan is for the baffle and the flare sections in 12mm. the baffle is a double so it ends up as 24mm..
keilamym
Posted: 22 November 2011 at 8:21pm |
darn good catch cravings.. i didn't realise the flare was 12mm also.. guess thats why its called a test build huh.. lol
cravings
Posted: 22 November 2011 at 8:33pm |
i built some earlier this year.. lots of thinking involved hehe
cravings
Posted: 22 November 2011 at 8:38pm |
no harm at all in making the flare from thicker material.. once the internal size is the same you're good.
i drew it all out in CAD myself just to completely familiarise myself with all the parts.. they turn out marginally different to the dimensions on the plans i think. worth learning some CAD for stuff like this.. but 2d cad can't work out the compound mitre angles for the vertical flare bits.. i think i just went at it with scrap bits and trial and error till i had them right (think it's 3.5° or something) if you don't know what i'm on about there... you'll get there.. Edited by cravings - 22 November 2011 at 8:39pm |
cravings
or (sorry just keep adding bits to my posts)... when i say "it's 3.5°" ... i think that's what i set my saw at..
keilamym
Posted: 22 November 2011 at 9:51pm |
im goin thru the test build now... mistakenly didn't buy any 12mm ply so back to the store i go... thanks cravings.. how do you like the mt122? im planning to replace my 8 yamaha s115s with 6 MT122s
