Why do you not see this in plans? |
Page <123> |
| Author | |||
tb_mike
Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
Posted: 19 April 2007 at 1:28am |
That meyer multi sub above probably is setup for a cardoid polar.
gazman - is that in theory or to your ears? Sure,we have out of phase 'late'bass emanating from the port,but does it matter at that frequency. The phase wrapping on a graph looks bad,but one has to confer with psycho acoustics to see what the ear can hear. Edited by tb_mike - 19 April 2007 at 1:29am |
gazman
Joined: 30 January 2006 Status: Offline Points: 100 |
Posted: 02 May 2007 at 7:41pm |
Hi Mike, sorry for late reply! I'd say its both the theory and the practice..think about using multiple types of sub over the same frequency range and all the horribleness that causes, same problem basically. As far that Meyer sub, obviously set up for cardiod use, weird they've used 1x 18" at the front with a 15, then 2 more 15's to provide the cancelling waves. Wonder how the 15 and 18 are setup to coherently sum together...
Cuppa Joe
Joined: 10 February 2007 Status: Offline Points: 23 |
Posted: 24 May 2007 at 3:14am |
Gazman- The 18's and the 15's on the front baffle cover different frequency ranges and have separate subenclosures. The pair of 15's on the rear also have their own subenclosure and tuning.
Tom- Did my homework: Each 18" driver in the PSW-6 IS double-tuned within its own cavity (via employing 2 sets of vents with differing lengths and Sv), as are the following Meyer Sound enclosures: MTS-4A, 18" driver subenclosure (only) 650P double 18" sub 700-HP double 18" sub 600-HP double 15" sub CQ series 2-way, fullrange cabs (This might not be a complete list.) EAW does the same thing with at least one of their older designs. This is not a new design tactic, but it's tricky to get the tunings right. John Meyer can be contacted through the Meyer Sound website (www.meyersound.com). |
jcasti1226
Posted: 25 June 2007 at 4:04pm |
This contains the descripcion of the box MTS-4. It even tells you the size and lenghth to each chamber.http://www.patentstorm.us/patents/5602367-de0scription.htmlI was wondering. I have heard stacks of meyer 700HP subs and i see different port size i can assume they are double tune also.Anyway how can we acomplish our own designs double tune. What are the tools we need to do it?
I don't think john meyer will answer questions on port size and length on the 700hp or other cabinets they produce.
Ibex
Posted: 15 November 2009 at 3:32pm |
Whereon do you relate to this fact? I can't find any information concerning your claim... ...maybe the diverse sized ports have different lengths to get the same tuning frequencies for each one?! |
DjMidKnight
Joined: 31 August 2009 Location: Abq NM Status: Offline Points: 298 |
Posted: 15 November 2009 at 9:02pm |
hermm.. i might be overstepping my self here BUT from what i understand that if you put ports in a common cavity of varying lengths and sizes the combind volume of air that can push through them all will set the tuning of the box. of course there will be differing amounts of resistance through each port but the sum of exchange would be the calculated frequency.
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 5992 |
Posted: 16 November 2009 at 3:06am |
Double tuning still gives only one resonant frequency per tuned chamber.
Edited by _djk_ - 16 November 2009 at 3:19am |
djk
Ibex
Posted: 16 November 2009 at 7:11am |
Ibex
Posted: 16 November 2009 at 8:28am |
Maybe Cuppa Joe was talking about such a system design?!
![]() DCR - Double Chamber Reflex http://www.claudionegro.com/projects/speaker/dcr/dcr.html It's obvious that the Meyer Subs have different sized ports, it possible that they are utilizing the DCR technology: ![]()
Edited by Ibex - 16 November 2009 at 8:29am |
Ibex
Posted: 16 November 2009 at 8:51am |
...but there is nothing mentioned on their web site in the sound lab:
http://www.meyersound.com/support/forums/talkshop/subs.htm Myth still busted! |
MusicXtra
Joined: 05 August 2009 Location: Netherlands Status: Offline Points: 249 |
Posted: 16 November 2009 at 9:44am |
Each bass reflex cabinet is a simple Helmholz resonator, so it is impossible to give it two resonance frequenties.
G-Man
Joined: 30 October 2009 Location: The Colonies Status: Offline Points: 41 |
Posted: 17 November 2009 at 4:02pm |
There was a HiFi speaker company a few years ago, that used round ports that were put in at an angle and the ends were cut at an angle, with the idea being similar to what you are talking about here (one port with a variable length). But when you look at the geometry of the thing, all you have in the end is a straight oval port.
You are better off using multiple ports (of any length) simply because of the reduction in port velocity and port noise, but other then that, not much benefit. As a side note, even though they are mostly used in HiFi market, flared ports are the best way to go. |
If it was easy, everyone would do it!
Page <123> |
