  New Posts New Posts RSS Feed - why doesn't anybody use Dynacord IPX / TGX ?
Line Array View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Line Array Quote  Post ReplyReply Direct Link To This Post Topic: why doesn't anybody use Dynacord IPX / TGX ?
    Posted: 11 April 2022 at 6:42am
it's pricey but it's easily better value than powersoft X4 for example which everybody uses
these amps have four 80 mm fans for the price of two 40 mm fans in the X4
and the heatsinks are also about 10 times bigger as well for the same price
and it has a freaking high resolution touch screen ( in the TGX )
yet literally nobody uses them at all
is it just because nobody knows about them or is there some other reason ?
best place on the internet >>>
https://dissidentsound.discoursehosting.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote Line Array Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2022 at 8:07am
forgot to add these amps can also be both bridged and paralleled and parallel bridged too
so you could have a single 20,000 watt channel if you wanted to try and fry a Powersoft M-Force for example.
it also has other nifty tech like it is stable into impedances below 2 ohms even BEFORE you parallel the channels ...
the amps are *MADE* in Germany
very cool amps.
why no love ?
Edited by Line Array - 11 April 2022 at 8:10am
jacethebase View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2022 at 10:06am
I know a few professional users that hold stock of these, most are EV stockists though.
I have a large EV system in a install and have though many a time about changing over to Dynacord.
Having had a quote (I have a direct Bosch EV account) I can confirm the pricing is right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2022 at 10:40am
I find it interesting that they use the IHFA-A-202 standard from a defunct institute circa 1978 for their power ratings. The document itself is impossible to find a copy of.
EIA-RS-490 replaced this standard in 1981, and that itself has been superseded by EIA/CEA-490-A. That's how the EIA burst ratings on other amplifiers are measured, so without having the definition of the frequency shaping, stimulus (crest factor and period), and such the power ratings can't really be compared.
Perhaps there's a copy of the standard in someone's library
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2022 at 4:33pm
Depends alot on whats in your area.
In my area its all LAB PLM and a few crowns.
Easy to rent some more if needed.
But TGX is great stuff. Really great Amp.
Would not use powersoft at all. Not rider friendly here.
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2022 at 8:35pm
very cool amps.
why no love ?
There is nothing German in them. Even the manuals are written on a paper made in China.
