  New Posts New Posts RSS Feed - Why is Windows Media Player distorting?
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Topic: Why is Windows Media Player distorting?
    Posted: 26 November 2016 at 6:29pm
For ease sometimes I just set up a playlist in WMP and play it at random. Lately I've noticed that after a while it starts to distort and I have to restart the computer. This has happened on 3 different computers. Any ideas?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2016 at 7:15pm
Are you using built in sound card or external?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2016 at 7:42pm
Question is why are you using windows media player?  Smile
http://www.foobar2000.org/download
Edited by Sypa - 26 November 2016 at 7:44pm
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2016 at 11:16pm
Or VLC Media Player..
Suspect the, "onboard software inbuilt sound" is stealing too much ram and/or cpu over time?
Lev??
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2016 at 11:33pm
Which version of Windows Ken?
Try £10 usb key sound card, see if it works better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 12:35pm
Lev, I'm using external sound cards. Operating system is Windows 10. I have 3 external sound cards. @ Sypa only use it for convenience. @ nicky I do also have VLC which I am using now and will monitor the situation. Your explanation sounds the most feasible so far.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 1:04pm
Worth watching the windows task manager (ctrl-alt-del and task manager) when it is happening. If there is any process that begins to take a lot of CPU time or RAM it could be your cuplrit.
Another thing to check is any AV s/w entering a scheduled scan or any s/w running an update in the background you can't see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 2:14pm
Yeah did try that but didn't see anything obvious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 2:57pm
Ken, what is machine make/model, CPU, Mem size, Hard disk size, age of machine?
Is Bios up to date?
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 7:48pm
Remember this happening on 3 different machines and 3 different soundcards. The one that I am using this moment is quite old, perhaps 5 years. It's a HP 2.4ghz with 4 gig of RAM. CPU isss AMD Athlon and there's 1tb hard drive. The updates are always applied. That's all the info i have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 8:39pm
Could be ancient sound hardware, wrestling with Windows 10.
Grab yourself a used £150 Dell E6420 laptop with Core I5 CPU, 4Gb Ram & Windows 7 COA.
Update to latest Bios.
Upgrade to Windows 10 for free.
Sure your problems would disappear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2016 at 10:19pm
Thanks for the advice Lev but this machine was upgraded from Windows 7. The other 2 machines are newer HP laptops upgraded from Windows 8 with newer external sound cards. These exhibit the same problem when listening for long periods.
This page was generated in 0.082 seconds.
