Why is Windows Media Player distorting? |
Post Reply | Page 12> |
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1510 |
Posted: 26 November 2016 at 6:29pm |
For ease sometimes I just set up a playlist in WMP and play it at random. Lately I've noticed that after a while it starts to distort and I have to restart the computer. This has happened on 3 different computers. Any ideas?
levyte357-
Are you using built in sound card or external?
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Question is why are you using windows media player?
http://www.foobar2000.org/download Edited by Sypa - 26 November 2016 at 7:44pm |
nickyburnell
Or VLC Media Player..
Suspect the, "onboard software inbuilt sound" is stealing too much ram and/or cpu over time? Lev?? |
levyte357-
Which version of Windows Ken?
Try £10 usb key sound card, see if it works better. |
knet94
Lev, I'm using external sound cards. Operating system is Windows 10. I have 3 external sound cards. @ Sypa only use it for convenience. @ nicky I do also have VLC which I am using now and will monitor the situation. Your explanation sounds the most feasible so far.
odc04r
Worth watching the windows task manager (ctrl-alt-del and task manager) when it is happening. If there is any process that begins to take a lot of CPU time or RAM it could be your cuplrit.
Another thing to check is any AV s/w entering a scheduled scan or any s/w running an update in the background you can't see. |
knet94
Yeah did try that but didn't see anything obvious.
levyte357-
Ken, what is machine make/model, CPU, Mem size, Hard disk size, age of machine?
Is Bios up to date? |
knet94
Remember this happening on 3 different machines and 3 different soundcards. The one that I am using this moment is quite old, perhaps 5 years. It's a HP 2.4ghz with 4 gig of RAM. CPU isss AMD Athlon and there's 1tb hard drive. The updates are always applied. That's all the info i have.
levyte357-
Could be ancient sound hardware, wrestling with Windows 10.
Grab yourself a used £150 Dell E6420 laptop with Core I5 CPU, 4Gb Ram & Windows 7 COA. Update to latest Bios. Upgrade to Windows 10 for free. Sure your problems would disappear. |
knet94
Thanks for the advice Lev but this machine was upgraded from Windows 7. The other 2 machines are newer HP laptops upgraded from Windows 8 with newer external sound cards. These exhibit the same problem when listening for long periods.
