  New Posts New Posts RSS Feed - Why kickbins too?
Why kickbins too?
LjudLahger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Topic: Why kickbins too?
    Posted: 29 July 2009 at 2:36am
Yeah why? I have seen alot of picks with 1850/186 horns with HD15 on top. I thought they are a nice solution with bass and kick, am I wrong?
//Swe
drivebycar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivebycar Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2009 at 12:34pm
You are right, they are designed as a 1 cab bass solution. Not sure why anyone would add hd's unless they wanted lots more kick.
Would probably make it sound worse than just building more 1850s/186's, correct me if im wrong..
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2009 at 1:31pm
the kick from a dedicated kick bin will be faster and cleaner.
i found that when i had 1850 horns, the kick region was a bit boomy and muddy, because there is only one driver trying to cover bass and midbass.
Hi_Varu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hi_Varu Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2009 at 2:12pm
depends from tops combination.
Natty K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natty K Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 5:45pm
surely if your gona try make your rig sound nicer putting HD154s in it isn't the way i thought they sound worse in there high end than 1850s
tekoffensive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tekoffensive Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 6:18pm
with rigs made up of just 1850's or 186's and tops, for example 6 1850's stacked two wide and 3 high on there sides, would all the 1850's be set to the same x-over freq to cover bass and kick, or would it be better to set the top two, for example to cover the higher bass and kick, letting the others focus more on the bass up to about 120hz??
or are the 1850's more than happy to cover it all up to 250 or whatever?? i thought the sound would get muddy??
i ask this cos im about to aquire some
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natty K Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 8:08pm
not as loud but maybe cleaner when u crank it but im a noob so wait for other adviceto be sure lol
Mrfern View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrfern Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2009 at 9:34am
Censored
www.rantnraveuk.com - partys in the south, underground radio and free downloads!!
ENTROBANG SOUNDSYSTEM - PURE FILTH!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Natty K Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2009 at 3:06pm
alright calm down
Dj Unresolved View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dj Unresolved Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2009 at 11:23am
i always wondered this but surely it would a bit rare as u have the same type of cab doin sub and mid. could someone please clear this up for me please.
DIRTY NORFOLK AUDIO SOUND SYSTEM
IF I SENT YOU MESSAGES REGARDING BUYING ITEMS OF YOU PLEASE MESSAGE ME I HAVE THE MEMORY OF A GOLDFISH. LOOKING FOR WIRES AND V-18 1000's, AND CHEAP AMPS.
torch1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torch1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2009 at 3:06pm
Exactly, 1850s sounds a bit 'honky' over 150 IMO, sound much better with kicks on top. Depends how low your mids will cut off aswell
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivebycar Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2009 at 6:08pm
Get phat mid tops and cross at 120hz :)
