Why my wireless mouse is not detected? |
Pizzaro ![]() New Member ![]() Joined: 21 July 2011 Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 21 July 2011 at 10:18am |
Hi, I just reinstalled my xp, actually somebody else did it and changed the damaged ram memory. When he used my computer the usb mouse worked. Now I brought it up home and my wireless mouse isntworking. I tried my USB mouse but still not working! What should i do? Edited by Pizzaro - 21 July 2011 at 10:20am |
TechnoChef ![]() Registered User ![]() Joined: 23 April 2009 Location: Oxfordshire Status: Offline Points: 1109 |
Try a different usb port, or another usb device in the same port that you know works.
If no response, check inside the machine that the ports are still connected... Wouldn't have thought drivers would be an issue but to check, right click on the my computer icon, click properties then in the hardware tab somewhere there should be a list of hardware, if the usb ports have an exclamation symbol over them, they ain't workin'! That's the limit of my skills! |
I think I'm in love with your mum.
slaz ![]() Old Croc ![]() ![]() Joined: 27 November 2009 Location: London E2 Status: Offline Points: 2676 |
I could probably take you a bit further down the problem-solving route than that, but its good advice for starters ..... |
anerly ![]() Registered User ![]() Joined: 02 June 2010 Status: Offline Points: 14 |
Need to load USB drivers for the motherboard?
