  New Posts New Posts RSS Feed - Wich cabs for 160/180 till 5k?
bartje2012 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bartje2012 Quote  Post ReplyReply Direct Link To This Post Topic: Wich cabs for 160/180 till 5k?
    Posted: 28 February 2009 at 10:33pm
Hi wil have
2x X1 sub - cross: 35 till 80
2x HD215  - cross: 60 till 160
Mids 160/180 till 5k
As for high im planning to get 2x beyma cp22 cross: 5k till 20k
they are long throw so should keep up with the HD215's and i picked them because i think a horn will have less high freq's (18k till 20). right? anyway they can be implemented in the mid cabs or i just build some xtra cabs for them :)
basicaly looking for a nice solution untop of the 2x X1's and 2x HD215's
but i dont wanna build complex cabs im looking for a simple/easy to build cab for mid :)
thanx in advance and cheers!
bart.
Rockin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockin Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2009 at 12:32am
What kind of music are you gonna be playing back through the system?
What size venues?
I assume you want the mid cab to incorperate the HF too?
Also i wouldnt worry too much about getting the top end to play from 18-20k so much ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote bartje2012 Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2009 at 12:39am
This varies from hip-hop/dubstep to drumm and bass/acid/tekno , but mostly just vinyl/cd/drumcomputer/synths
it must scale up to 2x X1 1000 watt and 4x HD15 600 watt each
so total = 4400 watt of bass
venue's will be in larger areas or outdoor.... but small audience 50 ish maybe 100.
and i now have old rcf Unita mid/high drivers wich sound very... uhm ... old :D
so need to replace them and the mid i use azre actually my bass monitors.
here is a link to my current set, soon i will receive my 2x X1 cabs to go beneath
looking for a mid high solution now.
http://img100.imageshack.us/my.php?image=img2460.jpg
