width of materialn in 186 horn |
BrainlessTekno ![]() Registered User ![]() ![]() Joined: 20 February 2023 Location: Slovakia Status: Offline Points: 188 |
![]() ![]() ![]() ![]() ![]() Posted: 20 February 2023 at 7:59pm |
so here is the deal, i have 1.5cm material but 186 is designed for 1.8cm.
How mutch damage would it make to build it with 1.5? is it worth it to buy 1.8?
Edited by BrainlessTekno - 21 February 2023 at 8:24am |
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1791 |
You surely mean 1,5 cm= 15mm and 1,8 cm = 18 mm?
It can be done, but you have to account for the missing 3mm in certain places. You should probably go through the whole plan in detail to make sure you don't end up with gaps or wrong size of panels. Extra bracing would probably not hurt. In general, this type of horn requires precise and tight construction if anything comes loose later, it will be hard to find which panel exactly is vibrating, and it might be hard or impossible to reach afterwards. If possible, rebate the horn path panels into the aide panels, and the braces as well .
Edited by bob4 - 21 February 2023 at 8:30am |
Sorry about my mistake on milimeters i edited it :D
Thanks i will manage it somehow i hope
