  New Posts New Posts RSS Feed - width of materialn in 186 horn
BrainlessTekno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Topic: width of materialn in 186 horn
    Posted: 20 February 2023 at 7:59pm
so here is the deal, i have 1.5cm material but 186 is designed for 1.8cm.
How mutch damage would it make to build it with 1.5? is it worth it to buy 1.8?
Edited by BrainlessTekno - 21 February 2023 at 8:24am
bob4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 8:23am
You surely mean 1,5 cm= 15mm and 1,8 cm = 18 mm?
It can be done, but you have to account for the missing  3mm in certain places. You should probably go through the whole plan in detail to make sure you don't end up with gaps or wrong size of panels.
Extra bracing would probably not hurt. In general, this type of horn requires precise and tight construction  if anything comes loose later, it will be hard to find which panel exactly is vibrating, and it might be hard or impossible to reach afterwards. If possible, rebate the horn path panels into the aide panels, and the braces as well .
Edited by bob4 - 21 February 2023 at 8:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrainlessTekno Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2023 at 8:26am
Sorry about my mistake on milimeters i edited it :D
Thanks i will manage it somehow i hope
