  New Posts New Posts RSS Feed - Wifi remote controller for the Ultradrive
 Post Reply Post Reply Page  <1 23456 12>
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2018 at 8:00am
Brilliant work, like everyone else cash waiting.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2018 at 1:48pm
Same here. Looks great!
tomelmore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomelmore Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2018 at 3:49pm
Top work!
I started the same project a few years ago using a Raspberry pi, Python and nodejs. As soon as i started getting somewhere I managed to loose my laptop and never bothered to buy a new one since. You can add me to the order list as well Big smile.
Lasse Lukkari View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 8:15am
Slowly getting there but at least one more iteration is still needed after this. I need to move back the RS232 connector about 0.5mm and replace the DC connector with another one the will align the plug properly with the case.
Edited by Lasse Lukkari - 19 May 2018 at 10:34am
bob4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 9:49am
wow that is GORGEUOS! Amazing work!
spongebob View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 11:05am
Possible to use some sort of latching power connector?
Awesome work btw
Post Options Post Options   Thanks (1) Thanks(1)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 11:11am
As i have said, i am buying two as soon as they are ready.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 6:04pm
The case has a proper strain relief built in so I decided to remove the connector completely to save some space. The wires will be soldered directly to the pcb. The other end of the cable is a usb A connector. Any basic USB charger should work fine.
scottylaroq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scottylaroq Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 6:46am
put me down for two if you will ship to canada.
dekra54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dekra54 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 10:04am
Just some ideas.... :
If youre going top use a USB Phone charger as a Power supply maybe you can add a FTDI USB Serial Chip and a Switch so you can use booth WIFI and direct USB connection. (Not simultainiously of course). Then you maybe also can use it like some kind of management interface for the ESP WIFI Chip.
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 10:59am
Also really interested! Very nice work Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lasse Lukkari Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2018 at 7:24pm
I got so lucky with the case.
