Wifi remote controller for the Ultradrive |
Post Reply | Page <12345 13> |
Lasse Lukkari
Young Croc Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Thanks(2)
I have no intention to make any money out of this project and even less to give any guarantees. I will release the board schematics under the same MIT licence at some point. The license is really permissive. Commercial use without creator attribution is completely accepted. Added note 14.4.2020: You still need to make the MIT license visible for the software if you distribute it. The hardware is released under Creative Commons — Attribution 4.0 International. The open source licenses do not mean you can claim this to be your own work and all copyrights still hold.
Edited by Lasse Lukkari - 14 April 2020 at 2:31pm |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Thanks(1)
Stupid question..... Is it possible to control several daisychained dcx's with your controller?
Amazing project! |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 560 |
They SHOULD inherently rebroadcast a RS485 network IIRC |
Lasse Lukkari
Yes it should support 16 devices but i have not tested this. In the upper right corner of the UI there is a drop down menu called "Select Device". They should all appear there. I edited the PCB layout so that it uses a ground plane. With these changes the board became single sided. I doesn't really matter in this case but if it would be mass produced the price would be around half compared to a 2 layer design. Edited by Lasse Lukkari - 12 February 2018 at 5:03pm |
Lasse Lukkari
Thanks(1)
Finally managed to put together the first board. Seems to be working fine.
I will most likely change the microcontroller to an older model called esp8266. Luckily it's available with the same footprint. The new esp32 seems to still have many hardware level problems. Although software workarounds for these bug are possible I will rather use a proven design for now. I will also create a boxed version with cables using the same board. This will be more suitable for touring rack installation and give better wifi range.
Edited by Lasse Lukkari - 04 April 2018 at 5:21pm |
Hemisphere
Thanks(1)
Great work!
djeddie
Thanks(1)
MarjanM
Thanks(1)
Let me know as soon as you have the first one ready. Ill buy it.
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
Thanks(1)
Top work!
JonB67
Thanks(1)
These look awesome.
I have cash waiting as soon as a version for mobile rack mounted units is available! So impressed!
Lasse Lukkari
From the back side
Edited by Lasse Lukkari - 05 April 2018 at 6:16am |
Lasse Lukkari
I will send you one for free once i'm done.
