Will New Turbomax Drivers Fit in Super Scoopers ? |
Page 123 4> |
Tekasis
Topic: Will New Turbomax Drivers Fit in Super Scoopers ?Posted: 27 February 2007 at 6:27pm |
Members,
A mate of mine who's not on Speakerplans has just acquired some of the new Turbomax 1200 drivers.
He's just realized that they are a bit deeper than the PD1850's & Void V-18 1000's. (Ain't measured against the Volt 18'' drivers yet)
He planned to fit them in some old scoops which he said he had specially built & tuned for PD1850's & they have the board in the rear chamber a few mm closer to the front than standard Super Scoopers.
Problem is they don't fit as the back of the magnet hits the board before sitting flush. Luckily he has other Scoops with a larger chamber to use.
So has anyone tried these drivers in standard Super scoopers as yet to make sure they fit ?
If they do fit, & the magnet is closer to the rear panel than the PD's or V18's could this fry/cook the driver ?
Cheers.
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 02 March 2007 at 5:06am |
Boss, your best bet is to ask Irration steppas there using the new Turbo max, or call Roy one of the guys who designed these monstors.
Sticks n Stones
Tekasis
Posted: 02 March 2007 at 5:45am |
Champ, Iration use Shortmans scoops, so they must fit. (Wont go into rear chambers again as you know)
Roy would more than likely have no idea about various scoops, but I may try him.
CHAMPION
Posted: 02 March 2007 at 6:43am |
What scoopers you them to fit into ?? ASS, Super scoops which ones.
I know you want some Dirty beeline, you want your scoops to be different !
Sticks n Stones
gingerbiscuit69
Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
Posted: 02 March 2007 at 6:12pm |
the title says super scoops so superscoops possibly...
just he has modified it a bit to tune for the rear plate to be a bit closer for the 1850 driver... |
Insomnia
Joined: 06 September 2005 Status: Offline Points: 1721 |
Posted: 02 March 2007 at 8:48pm |
Tek wats the depth of the turbomax. il see if they fit the superscoops im building
Tekasis
Posted: 06 March 2007 at 5:18am |
Still trying to find out Insomnia, just been told they are a bit deeper than the Fane XB's.
Sunil
Joined: 21 September 2006 Location: United Kingdom Status: Offline Points: 408 |
Posted: 06 March 2007 at 5:56am |
Lynx, its 8 n a half inches deep.
Tekasis
Posted: 06 March 2007 at 6:14am |
Cheers mate, that's about 215mm.
Looking at the plans, there's about 202mm between the front & the rear board. If I've calculated correctly.
I think the magnet of the driver will be either touching or very close to the board in the rear chamber. (Luckily in these scoop designs the drivers are front mounted)
That's if it fits at all.
Need to send one to Insomnia.
Edited by Tekasis - 06 March 2007 at 7:36am |
Sunil
Posted: 06 March 2007 at 7:16am |
yeah, how deep is the 1850?? Less than the turbomax???
Tekasis
Posted: 06 March 2007 at 7:19am |
Yep, PD1850 & v18's are less.
Tekasis
Posted: 06 March 2007 at 7:37am |
Sunil, how thick is the chassis of the turbomax ? Edited by Tekasis - 06 March 2007 at 7:38am |
Page 123 4> |
