Will this driver work in the Punisher?... |
kpippen
Joined: 04 July 2007 Location: United States Status: Offline Points: 174 |
Topic: Will this driver work in the Punisher?...Posted: 10 December 2007 at 1:31am |
Hello everyone, Since the question comes up often I decided to post the Hornresp parameters of the Punisher loaded with the Ciare 12.00SW and P Audio SD-12 drivers... I recently drafted the Punisher in AutoCAD so I could get exact measurements for the calculations… I have also corresponded with David McBean on numerous occasions in regards to the proper usage of his Hornresp program for modeling horns… David,...I thank you very much for your patience and for answering my questions!... If you want to know if a particular driver will work in the Punisher I recommend that you download David’s Hornresp program and enter the parameters as illustrated below with exception to those specific to the driver… Note that the latest version calculates and displays the compression ratio as you mouse-over either S1 (the cross section volume cm3 of the first horn section) or SD (surface area cm2 of the cone)… If you look at the information box at the bottom of the illustrations below you will see the compression ratios… Be advised the compression ratio is a key factor in regards to the driver's survival... For you sticklers: I added the volume of the baffle cut-out to the VTC (volume throat chamber) parameter by using the formula (3.14 Pi X the cutout diameter ^squared X 15mm /4)… Punisher parameters with Ciare 12.00SW
Punisher parameters with P Audio SD-12
Cheers! Kev |
turn on, tune in, drop out
Hey Nipper,...we gotta have more cowbell!!! |
darkmatter
Joined: 26 February 2005 Location: LDN Status: Offline Points: 2419 |
Posted: 21 December 2007 at 11:34pm |
Cheers for posting this
Would the higher compression ratio for the sd12 suggest higher sensitivity, but possibly(?) lower max spl and more stress on the cone?
I guess the problem is the new sd12s are rated at 600W, whereas the t/s specs on the site are for the 500W. I don't know whether t/s have changed much in the new version or where they're published! Edited by darkmatter - 21 December 2007 at 11:37pm |
kpippen
Posted: 22 December 2007 at 12:38am |
Hello darkmatter,
Yes the SD-12 now has a 4.5"VC and is rated at 600W... The SD-15s have a 4.5"VC and are now rated at 800w... I have found the information given at the P Audio website and by their distributors to be unreliable at best but so far it's been quite pleasant... I just recieved eight P.A. drivers and it was like opening a box of Cracker Jacks... Irregardless of what was printed on the box...there was a nice surprise inside!...
Kev
ceharden
Posted: 22 December 2007 at 1:51am |
SD-12 in a Punisher has been done with good results I believe. Mircea Bartic is the man to ask...
kpippen
Posted: 22 December 2007 at 1:57am |
@ceharden
Yes,...my bad... Thanks for pointing that out... Mircea is definately "the man" for any questions regarding the Punisher loaded with the SD-12...
Kev
darkmatter
Posted: 22 December 2007 at 6:41pm |
Haha! Got the impression it might be a bit like this with P Audio
ceharden - yeah I was definitely going to ask if Mircea wouldn't mind giving some advice if I do go for sd12s. I imagine he changed rear chamber volume slightly, but I'm not too sure. I've been wondering whether it's worth tweaking the whole design very slightly, but I'm nervous about deviating from Walt's design with such limited knowledge and when all I really want is a working system in the shortest time possible!
MikeHunt79
Joined: 12 February 2009 Location: Bristol, UK Status: Offline Points: 352 |
Posted: 01 April 2009 at 5:29pm |
Any chance you could fix the pics please? I'd like to see how the punisher compares to other designs...
I'm English, and as such I crave disappointment. I actively seek it out.
jonminns
Joined: 13 April 2008 Location: United Kingdom Status: Offline Points: 1877 |
Posted: 02 April 2009 at 1:38am |
so if you want a system that's proven to work why not just use the driver it was designed for?
