Winding 2 cranks, same direction simultane |
Post Reply | Page 123> |
kevin tyler
Old Croc Joined: 15 April 2007 Location: Spain Status: Offline Points: 3402 |
Posted: 01 November 2017 at 11:02pm |
Hi guys.
Has anyone figured the easiest way to raise a goal post with two wind up stands either side using a single cordless drill, I’m thinking of embedding two cordless screwdrivers in to two meters of pipe, but I’m sure there is an easier way, and it’s not nudging each side up a bit at a time by hand as it seems to put a lot of pressure on all the joints in the manual peg and hole type stands I’m using and I’m thinking cranks would be more elegant. Cheers. Kev Edited by kevin tyler - 01 November 2017 at 11:03pm |
mini-mad
...get someone to stand the other side helping You?
kevin tyler
Hi guys.
I do everything alone often when the bars are shut, or are being cleaned post gig and My partner has a two hour round trip to the gigs so we compromise, he rolls up when the gear is all done but I’m getting no younger. Cheers. Kev |
MarjanM
Two normal (non cordless) drills somehow attached on both cranks with one remote switch?
mini-mad
..some sort of worm drive? You can buy JUST 12v drill/lathe mother off eBay for around a tenner. Just a case of hook up the worm gears. I CHOOSE worm as it's a nice slow(ish) smooth movement with good torque. |
kevin tyler
Thanks Marjan
I was thinking maybe two of these semi permanently clamped to the stands with a common trigger could do it. Are these powerful enough you think ? https://www.homedepot.com/p/Ryobi-18-Volt-ONE-3-8-in-Right-Angle-Drill-Tool-Only-P241/100342144 |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
How about using windscreen wiper motors, they are about
£20.00 each new on ebay? There is a video on youtube that shows a guy making motor powered scissor jacks with them… they lifted a hell of a lot of weight. Something like this: https://www.youtube.com/watch?v=vxhBMiyy3y0 |
kevin tyler
Hi guys
I have the millennium wind up stands, they are fine for my use, 4 times a week maximum, and seem quite well made. Having motors on them will be nice, especially when the crossbar is 12 foot up in the air and someone has forgot to plug the power or dmx cable in |
SouthwestCNC
Sounds like you want to find scrap man that deals with electric wheelchairs. they often get actuators off the lifts on them. They'd be ideal. Can get you a number for a guy that has a load.
mini-mad
I've got it!!! You want electric car door window motors!!!
They already have 90% of the drive much that you need, it's just a case of marrying up that to the hand cranks. All works on 12v so just a case of lashing up either a 12v battery or a 12v wall adaptor to drive them! It's borderline genius..... |
norty303
Just use truss adaptors that allow the truss to move in them (e.g. not clamp down half couplers), or get the hinged ones.
You can move each side a reasonable way then before moving to the other side. Much simpler/easier than what you seem to be wanting. |
SouthwestCNC
Dc motors wont raise it evenly. But some stepper motors will, they'd need gearing tho.
