Winding 2 cranks, same direction simultane |
Post Reply | Page <123> |
Author | |||
mini-mad
Doesn't need evenly... just slow and smoothly. |
SouthwestCNC
In that case windscreen motors isnt a bad call. The most expensive component would probbably the reverse polarity switch to reverse direction. Found these extremely expensive for what they are. Edited by SouthwestCNC - 02 November 2017 at 1:19pm |
SouthwestCNC
Torque all down to gearing. Will need gearing. For every kg you need 0.1n/m of torque minimum generally on a screw or rack lift.
Edited by SouthwestCNC - 02 November 2017 at 1:24pm |
mini-mad
Ok, but the window motor has all the gears in place ready to hook up... two long cables on two separate hand held buttons so you can control the rate at which the sides go up and at the end of the night turn the battery around and bring it down again. It's the most simplified thing I can think of. |
APW
A wiper motor also has all the gearing required and is significantly larger than a window winder motor.
Edited by APW - 02 November 2017 at 2:24pm |
SouthwestCNC
is a good suggestion aWindscreen wiper motor would stand more of a chance at lifting any kind of weight. a window motor is part of a slider mechanism that generates alot of the torque that lifts the window.
toastyghost
Just do this, making a mountain out of a molehill really… |
kevin tyler
Old Croc Joined: 15 April 2007 Location: Spain Status: Offline Points: 3402 |
Hi guys.
I have sorted it out, I was watching an old cowboy film and was inspired by the old levers on the locamotive train wheels. With the stands about 2 meters apart with the original crank handles facing forward, i put some clamps on the breaks on the stands, then I drilled two holes in a 2m plank the size of the handles and managed to raise both sides up without too much difficulty, using a sort of rotary bench press technique. I will investigate the electrification process further though. Thanks for all the advice. Kev |
Jasonstry
Young Croc Joined: 11 September 2007 Location: Cannock. J11 M6 Status: Offline Points: 1367 |
FWIW, I use a pair of Easyhoists with hinged truss adaptors or, quite often, hinged big bens for this sort of thing. 2 x 2m lengths of alli scaf with stands 1m in from each end. Total weight close to 60Kg, UDL which is the SWL of a single Easyhoist. Might have to walk a 2 meters a few times.....
Down with signatures!
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
I like this thinking (im thankful that I have someone to wind mine up... though she doesnt always match the speed ) the only thing that worries me, is that this assumes every setup is 2 meters (unless you play the same place in which case... its not a problem) Edit.... just thought, I wonder if an extendable pole would work (shower pole or even fishing), that way if its not 2m you can extend / reduce to suit
Edited by IainB - 02 November 2017 at 5:24pm |
Jasonstry
Or you could drill more than one hole at each end.....
kevin tyler
Yes good points guys.
It’s early days right now, obviously in an empty gig you can walk 2 or 3 meters and wind up six inches and then go back and repeat, unfortunately in real life you set your gear up against the back wall during the day but can’t raise it up because the fixtures are blocking the telly etc, so you go back later and ten lads who have been on the ale all day have put a couple of tables in front of your stands and are not moving for anyone, and so yes your right about me making a mountain of a mole hill, but it’s all molehills at the dog and duck sometimes, if I had a pound for the amount of time the drunks block the doors when you are trying to hump your gear in and then ask is that heavy mate etc, so I just try to make stuff as idiot proof and stress proof as possible. Cheers. |
