Windows 7 |
IainB ![]() Registered User ![]() Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
![]() ![]() ![]() ![]() ![]() Posted: 01 April 2018 at 5:53pm |
I made the move over to Win 10 on all my machines... but want to roll back my music, lighting and laser laptops. Normally I would just use the rollback function but being a smart ar*e once I thought they were stable did a complete format/rebuild on Win10 so that option is no longer available.
What is the best (and more importantly legal) way to get hold of copies of Win7 so I can re-install?
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
Do you have license stickers on PC's? If so any appropriate CD (OEM) will install from that key
No stickers (sometimes under battery on laptops) then: Turn off your AV and run https://www.magicaljellybean.com/keyfinder/ This should give you the product key and type (Pro or Home), then you can use ANY Win7 CD of correct sort (pro or home). Can send you one if you need, or eBay full of them. If they are Dell and not older than about 2009 any Dell CD will work and activate. Others do this but not as across the board. Ignore the Dell bit in the link below. An OEM 7 disk will activate from this key if you cannot get original codes. (can send you disk) https://www.ebay.co.uk/itm/BARGAIN-DELL-WINDOWS-7-32-BIT-64BIT-1-COA-PRODUCT-KEY-SCRAP-PCs-SCRAP-LAPTOP/263492882377?hash=item3d59664fc9:g:SzAAAOSwfWpagczO Edited by nickyburnell - 01 April 2018 at 7:56pm |
Thanks Nicky
![]() Time to go key hunting
Dot forget drivers, get them all ready from mfr sites
Its been a long time since I used to build PCs (used to live on Overclockers) so I hadnt even thought about hitting websites to get drivers ready, thank you again. Now to find out where I put my Win7 disc, had enough of Win10 doing its own thing when it wants (even when Ive rebooted a couple of times before a gig to make sure its not waiting to go... oi oi - im going to do an install now, getting to said gig...then laptop going ah yes old bean, I need to do an install)
If you need one shout, have, "proper" ones :)
If 10 Pro you can disable updates in gpedit.msc Home is a little harder but you can defer on latest build. Or https://4sysops.com/archives/disable-windows-10-update-in-the-registry-and-with-powershell/ Edited by nickyburnell - 01 April 2018 at 9:40pm |
