  New Posts New Posts RSS Feed - Windows help
Windows help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Topic: Windows help
    Posted: 15 March 2018 at 11:37am
Does any one know why this keeps poping up on my laptop screen
its only being happeing for few days now, bloodly anoring tbh i have no idea at all
Thanks
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2018 at 3:40pm
How did you install/activate that version of Windows?
Did you use authentic CD and COA key?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2018 at 6:40pm
Sorry Lev
im not at your level at all with pc/laptop ect Smile
Had my laptop tottaly wiped and pc man fully instaled windows 10
be fine till orther day, now this keep popping up , after been shut down or laptop lid closed
Thanks
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2018 at 7:18pm
Seen this on UEFA Bios machines where the 8.1 was installed with silly BIOS serial.  Seems some just, "let go"
But questions:
1. How long ago was the install done?
2. Was the machine on 7, 8 or 10 when you got it?
3. If on 7 is there a license sticker on bottom?
I'm guessing its an 8.1 machine. The code in the bios just gets forgot/confused.
You can try to activate by phone
You can reset bios to default but will probable have to re-boot with shift key held down to get there
You are going to need some knowledge. From an elevated command prompt (google it) type
 slmgr -rearm and re-boot.
 Failing this go back to the PC man, it's a messy fault
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2018 at 11:15pm
Install about a year maybe more ago
yes my laptop was on windows 7 originaly
not sure what you mean license skicker
wow quite complacted fro me tbh
big thanks for your help tho
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2018 at 11:16pm
Its still all working fine tbh
its just i have to keep clicking close
if that any help too
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2018 at 7:08am
If it was on 7 there may be a windows license on bottom. Might be under battery, take a look. If not then run winver    (just like that) from the search box and when it finds it right click run as admin. Let us know which version of 10, Home or Pro?  Plenty serials about here, can talk you though putting a new one in. (legitimately)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2018 at 11:01am
Big thanks for your help nicky
tbh cant find the license , by the task bar bottom right, is that correct?
pretty sure its just the home windows 10, its nothing fancy standed i think
so the PC fella has put a dodgy windows on my laptop then, it seems?
thanks again
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2018 at 2:08pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
Sorry Lev
Obviously this dude did something dodgy.
This is why proper PC Techies charge real money, as opposed to cowboys, who offer botch job for cheap.
In last 2x years, I've sold at least 5-10x PCs/Laptops, where I upgraded machine to new version of Windows 10, never this problem.
But then again, I only deal with DELL machines, NOTHING ELSE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2018 at 3:21pm
Not necessarily dodgy, seen this happen on a few, especially embedded BIOS serial (late 7 and all 8 8.1) jobbies, but then I have hundreds through my hands a year.  MS uninterested, simplest solution is to change serial.
Edited by nickyburnell - 18 March 2018 at 5:18pm
transvisionvamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote transvisionvamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 3:27am
You can try the sysprep dodge.
Google it.
BACK YOUR STUFF up FIRST!!!!!
This page was generated in 0.046 seconds.
