WinISD suggested port size |
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
Posted: 29 April 2023 at 8:37am |
Why does it suggest such small ports?
Edited by Keen - 29 April 2023 at 8:39am |
DMorison
Thanks(1)
I don't think it suggests port size per se, rather it just defaults to one of the most common sizes (4" IIRC).
Use the vent airspeed chart and adjust to suit your own needs.
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
Everything WINISD presents when a sim is initially opened is based on the default parameters and 1w of input power, you can(and should) then alter the box size, port tuning, and port number and size to achieve best results for the driver at it's rated power level using the driver excursion and rear port air velocity tabs as guides.
