  New Posts New Posts RSS Feed - Wiring Speakons in Parallel
Wrighty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2008 at 4:47pm
Fair comment. The only time I use 2+ and 2- is for the HF in my hi-mid boxes and my rig is 4-way active, so little point in linking 2+ and 2- through anywhere else.
ALL YOUR BASS ARE BELONG TO US.
rich21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich21 Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2008 at 4:52pm
not just for mid -hi
also means i can do 1 bass bin on each core or subs + kick
too many options you miss out on .. just because you didn't wire the pins 2
it also works for me as i always use 4 way spk-on leads
edit to add:
i have just read my own post and it sound like iam having  a go
i dont mean it to .... what i mean is I HAVE FOUND IT VERY USEFUL and therefor i would all ways link pins2
Edited by rich21 - 30 June 2008 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrighty Quote  Post ReplyReply Direct Link To This Post Posted: 30 June 2008 at 5:07pm
Yeah, as I said, fair comment - no offence taken :)
I didn't mention it, mainly because I don't use it, I guess! Until I expanded my rig to 4-way active (building new hi-mid cabs in the process), I didn't have any 4 core Speakon cables. My bass bins are on 2 core 4mm, with an independent run from each one back to the amp rack, to minimise cable losses and maximise damping factor (another topic...).
goldylocks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goldylocks Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2025 at 8:09pm
Why do you need to do this?
