  New Posts New Posts RSS Feed - Wiring the Comp + 12"
jwdrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwdrain Quote  Post ReplyReply Direct Link To This Post Topic: Wiring the Comp + 12"
    Posted: 12 April 2012 at 3:01am
Im pretty confused about how to wire the speakon to the mid and the compression driver in my MT 121s...
Correct me if Im wrong, but surely if you wire the speakon to the 12" driver to the compression driver they are all receiving the same signal. Surely if you have a 150 watt compression driver and a 400 watt 12" driver though, then that signal will blow the compression driver??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2012 at 3:38pm
You need 4 pole speakon. 1+/1- to the 12 and 2+/2- to the HF.
https://encrypted-tbn0.google.com/images?q=tbn:ANd9GcRiQtFv5AN7068TwjStNPHkX8yH3aN8CLL8Z_BcT0BLz0qGLE2gSw
Edited by MarjanM - 12 April 2012 at 3:39pm
