  New Posts New Posts RSS Feed - Wiring up
Wiring up
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 1:23pm
On this forum is a thread about changing the fixed high pass filter in cheap behringer cx crossovers, they are usually set at 25hz which is far to low for your application, it was only a simple component change and could be set at 30, 35,40 etc, this would be a good cheap option for you, I will have a look later and put the link here, second hand they can be very cheap.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 1:31pm
If you can not be bothered with designing a new enclosure then you are best off leaving the path length dimensions the same as they were - Unless you know a good way of scaling the speed of sound!
You could on the other hand narrow down the cabinet to suit your little driver. At least you will have a fighting chance of getting something that will function as a speaker.
A high pass filter stopping the cone from over excursion at low frequencies is a fundamental part of most speaker designs. Without it you will be restricted to low power use - what's the fun in that?
Some budget electronics have a high pass filter built in. Try to use one if you can.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 1:40pm
Don't worry about them working too much, just think of the whole project as good woodwork practice with a bit of fun on the side. Always fancied making some tiny horns myself just for the fun of it, nuts to the physics.
