wiring |
spallum ![]() Registered User ![]() ![]() Joined: 03 February 2010 Location: norfolk Status: Offline Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 13 April 2010 at 4:25pm |
hi i was just wondering were to put me holes for the speakons if i put if behind the corner brace i will have to drill a hole through it is that ok? and do i need to fix my wire to something with brackets so it doesent move about or will this not matter. cheers
imageoven ![]() Old Croc ![]() Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2163 |
I would fix down any flappable length of cable, movement breaks things over time.
If you have to pass the cable through a panel, a tightish hole and some sealant will keep thing airtight. personally I would put the connector somewhere you won't see the cable if you look into the horn. I would also put it where it minimises the cable length inside the cab. negligable in the real world, but if everything else is equal, why add a resistive factor you dont need? |
nice 1 mate ive already drilled my holes behind the corner brace now.... bummer shud b orite tho whaaat would u sugest to pin the wire i wud of thought pins and brackets but wouldnt they fall out over time due to the vibrations and i wouldnt wanna
Yes, I'd avoid pins. There's something I know as "P clips" which you can screw down, or look at cable tie bases, some of these can be screwed down.
merlinmarshall ![]() New Member ![]() ![]() Joined: 04 August 2009 Location: bucks Status: Offline Points: 3 |
what wiring/cable are people using in the box?
corell ![]() Young Croc ![]() ![]() Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
any 2x 2,5 mm copper cable will be fine
thanks.
