  New Posts New Posts RSS Feed - wiring
wiring
spallum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spallum Quote  Post ReplyReply Direct Link To This Post Topic: wiring
    Posted: 13 April 2010 at 4:25pm
hi i was just wondering were to put me holes for the speakons if i put if behind the corner brace i will have to drill a hole through it is that ok? and do i need to fix my wire to something with brackets so it doesent move about or will this not matter.
cheersSmile
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2010 at 10:31pm
I would fix down any flappable length of cable, movement breaks things over time.
If you have to pass the cable through a panel, a tightish hole and some sealant will keep thing airtight.
personally I would put the connector somewhere you won't see the cable if you look into the horn. I would also put it where it minimises the cable length inside the cab. negligable in the real world, but if everything else is equal, why add a resistive factor you dont need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spallum Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2010 at 12:09am
nice 1 mate ive already drilled my holes behind the corner brace now.... bummer shud b orite tho whaaat would u sugest to pin the wire i wud of thought pins and brackets but wouldnt they fall out over time due to the vibrations and i wouldnt wanna my driver upConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2010 at 12:18am
Yes, I'd avoid pins. There's something I know as "P clips" which you can screw down, or look at cable tie bases, some of these can be screwed down.
merlinmarshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote merlinmarshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2014 at 8:35pm
what wiring/cable are people using in the box?
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2014 at 8:40pm
any 2x 2,5 mm copper cable will be fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote merlinmarshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2014 at 3:11pm
thanks.
