  New Posts New Posts RSS Feed - would it make a diff?
Insomnia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Topic: would it make a diff?
    Posted: 10 September 2006 at 2:16pm
Hi
would it make a difference if the driver access panel for the 186/1850 horn etc was put at the top of the cab and not on the back? As you could simply drop the driver in and bolt it down securely without it being so fidlly when its on the back panel?
Just a thought
would like to hear people responce on this
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Insomnia Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2006 at 11:05pm
i guess not
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2006 at 6:23am
It would make the driver firing straight onto the acces panel at close distance so one could aspect the need for bolting it down more secure.
Wkr Johan
gingerbiscuit69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gingerbiscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2006 at 7:23am
you would need to adjust the plans i think, as the gap between driver and baffle is tiny anyway, so making it 18mm closer from the mdf, and and extra bit of the driver, will mean it will effectively take away 2cm of the baffle height (which is only 11cm in the first place)! best stick to what the plans say i think.
