Would this be only stupid thing to do? |
Page 12> |
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Topic: Would this be only stupid thing to do?Posted: 25 June 2008 at 6:59pm |
http://koti.mbnet.fi/parkerf/1850/1850ext.jpg
Something like that with biiig butterfly catches and some heavy bracing of course. I drew that one 115cm long so there could be two 1850s on their side on top of that as a kick bin. I haven't done any calculations, only rough drawing. That thing should add something like one metre of length. |
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 25 June 2008 at 8:30pm |
Been thinking along those lines as well (other cabinet). You could most likely leave the rounding bit, making bracing and building a lot easier/cheaper. From tests so far vibration between cabinets didn't seem so much of a problem, but didn't test with more than 600 W.
It doesn't seem to work on every cabinet tho, sometimes the added length in contrast to the added mouth area is just plain wrong. Definately worth a simulation.
Regards Johan Edited by mobiele eenheid - 25 June 2008 at 8:35pm |
Hi_Varu
Joined: 17 January 2008 Location: Italy Status: Offline Points: 181 |
Posted: 26 June 2008 at 11:16am |
interessant!...hope it will add db-in the 20/40hz zone...
mr ROG??? |
Deadbeat
Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Posted: 26 June 2008 at 1:09pm |
Rog's not here anymore...
Check out Walt's modular horn, for something similar. If I'm not mistaken, the B-Zero works with 2 horns as well. Edited by Deadbeat - 26 June 2008 at 1:09pm |
Away on extended leave.
Death_blooms
Joined: 03 November 2007 Location: United Kingdom Status: Offline Points: 98 |
Posted: 26 June 2008 at 9:40pm |
that looks rather large
pfly
Posted: 26 June 2008 at 11:37pm |
Of course it looks large, I believe you couldn't do much smaller 2.5 meter long front loaded horn with a mouth even remotely big enough? The point is it being modular it shouldn't be too hard to move around and if there's no need for extra sub frequencies, the extension could be left in the storage. I'm not capable of modelling the horn (newbie me!) but that sketch can't be far out, if someone is bored enough to try to model it I would be really nice!
Death_blooms
Posted: 27 June 2008 at 9:18am |
oh so the extension will be detachable? nice idea
snowflake
Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3443 |
Posted: 27 June 2008 at 11:39am |
can't acces that link. can you post the image please. cheers
Phil
Hi_Varu
Posted: 27 June 2008 at 4:38pm |
any expert commet?
Edited by Hi_Varu - 27 June 2008 at 4:40pm |
Hi_Varu
Posted: 29 June 2008 at 7:28pm |
so???
Edited by Hi_Varu - 08 July 2008 at 1:54pm |
tommysb
Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
Posted: 29 June 2008 at 8:33pm |
Not an expert, but it'd be worth doing (trying) definately, I've often thought of doing similar myself! Longer horn+bigger mouth = lower FS and higher efficiency as far as I know. It wouldn't cost much to try, and if you have the storage space, what is there to lose?
mobiele eenheid
Posted: 30 June 2008 at 11:02am |
Added in the 40 -50 Hz area mostly, 40 Hz + 3-4 dB.
Such a thing is easy simulated in Hornresp.
Regards Johan
Page 12> |
