  New Posts New Posts RSS Feed - WSX Loaded with Void 1000
 Post Reply Post Reply Page  <12345 6>
chilli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chilli Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2005 at 12:29pm
wooo! ran the wsxtras(like it..) last night, just a pair in one stack each one fed from a bridged ep2500 at 8 ohms. woah! shocking! shook shot glasses off of the bar and made for some seriously nauseating bass if you put your head near the horn mouth. the room had about 250/300 people in it and they easily provided enough thump to shake the whole place. having tried real wsx's in a pair with about 900w each, these certainly were louder, we set the hpf to 40hz and sat back and enjoyed.
seriously impressed, next time we'll try about 1500w into each..might need to get some bigger tops though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chilli Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2005 at 12:34pm
oh yeah, the ep2500's at 8 ohm stayed reasonably cool and i certainly havent got any complaints as to the output. 400 for 2 x 1300w is pretty good value in my book, we tried them at 4 ohm, but they got pretty hot pretty fast and as they were going to be ragged all night and seeing as we had a spare ep2500 with us i thought it was much the better option to run at 8 ohm.
also anyone know of any drivers suitable for a wsx that'll be available in the US?
MixMan X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MixMan X Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2005 at 3:06pm
What's this talk of flare extenders, what are they like?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chilli Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2005 at 3:47pm
cav in bournemouth had them specially made for the slinky tour, apparently they were large barndoors that bolted onto the front of stacks of 6 wsx, lengthening the horn path and coupling the cabs.
only heard of them never seen them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2005 at 7:08am
What would be the good parameters for VSX driver
Minimum EBP
Minimum BL
Fs
Xmax
Qts
AgentRied View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentRied Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2005 at 7:42am
Your not wrong there mate once Marcus and I have build another set of WSXtras gonna need some serious tops...
A new project for the new year...
He Who Dies With The Most Toys... Wins
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2005 at 7:48pm
Easy to design and make. Probably just doubles the mouth area in a path length of about 1metre. Expansion only on one panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2005 at 7:50pm
Minimum EBP
Minimum BL
Fs
Xmax
Qts
Something similar to the original which is the RCF18 300 or whatever.. Fs ~36hz Qts ~ 0.3 Xmax >6mm
twinnypaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinnypaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2005 at 8:03am
how deep is the rebate and would a rcf s800 fit in
COWFOOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 02 January 2006 at 2:37pm
Congrats Agentried: Great job.You inspire me.
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2006 at 6:35pm
i found this plan too but not the angles of it ....anybody have this ?
it's really hard to make thisone if you don't get this ....
speed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote speed Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2006 at 6:35am
do you think the bc tbx work fine in this horn
