  New Posts New Posts RSS Feed - WSX or WSXtra?
WSX or WSXtra?
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 2:25pm
Originally posted by junoprobelaunch junoprobelaunch wrote:
Thanks for that and yep, after pretty extensive research I do indeed believe they are exactly what I need at the mo. Where exactly can I get a spacer ring ? Is it something repurposed ?
How many do you want?
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 8:50pm
He has no shame, just seems to glean what he can from the web and stick it up.
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2018 at 10:04pm
Is your version of the ss15 up on there yet?
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 10:38am
No Just the TH18 and the Cubo Sub drawing I did for Mr Cubo….Smile
citizensc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote citizensc Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 11:38am
Maybe its because I haven't contributed any plans to the community, but as someone who has, whats the issue with making a sort of index of publicly available plans?
For me, its great to be able to browse plans, find one that interests me, then do further research which typically leads to the source of the plan, eg your TH-18 thread.
junoprobelaunch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junoprobelaunch Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 2:20pm
You think Martin Audio are just going to "repurpose" something they had lying around when upgrading a professional, high output subwoofer to take advantage of newer, higher excursion drivers?
No - it'll be a CNC'd piece of the same plywood used to manufacture the rest of the cabinet, sized to do the exact job it's required to do.
No of course not , however last time I checked they also didn't produce WSXtras and was unaware the updated version required such a ring.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 4:46pm
I did not say it was an issue - I did not even mention that I had a couple of plans on his site until I was asked a question.
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 5:14pm
WSX - Original with RCF Driver
WSXa - Newer with New driver, same as the ws218x and a spacer ring.
WSX Extra - same design as above but with a Void driver.
This is the only 3 versions of the cabinet that I know of. Please note the WSX Extra is a free party name and is not associated with anything Martin Audio.
All the best.
Jason
At least you are agreeing with each other...
Spacer rings can be very necessary when dealing with high excursion drivers. Would not be the first time I have seen someone put up a cab design that would destroy their nice new expensive driver. With some drivers having 30mm excursion a double thickness baffle can be necessary.
