WSX/ WLX DIFFERENCE? |
Post Reply | Page 12> |
Author | ||||
justamadman
Registered User Joined: 13 May 2007 Location: United Kingdom Status: Offline Points: 1118 |
Posted: 02 November 2008 at 1:09am |
besides the obvious.
they have the same frequency response and the only real detramental difference i can see is the output of the driver. |
in front of the bass bins baby
dj-panoramix
Registered User Joined: 28 September 2005 Location: France Status: Offline Points: 462 |
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
apart from the obvious physical difference that Mr Panoramix has kindly linked, the main one is the target market and what size stacks you're going to stick them in.
WSX should be killer in larger stacks and events, WLX for smaller.
Away on extended leave.
m.j.tandy
New Member Joined: 08 July 2009 Location: England Status: Offline Points: 3 |
WSX subs are the dB's (Dogs Bollock's) brill in stacks of 4 or 6 or even 8 I love my WSX clones.
dj-panoramix
does somebody have the wsx hornresp parameter ? specially VTC and ATC ...
kiriiz
Registered User Joined: 09 January 2009 Status: Offline Points: 70 |
WLX can play indoors WSX in 70% - no.
WLX can play itself one per side - WSX - no. WLX - great pressure in 1 meter - WSX - only from 3 meters. WLX - no pressure in 10 meters - WSX - will kill you (if in stack). So for indoor usage WLX (and other ported horns) is the best way to go. WSX - greatest outdoor bass horn i've seen. |
asaa00
Registered User Joined: 28 January 2008 Location: Los Angeles Status: Offline Points: 358 |
really? wsx models near-flat from 45-100 in singles... |
asaa00
WSX= VRC: 88 LRC: 20 ATC: 435 VTC: 18000 S1: 688 S2: 1238 exp/con 62 S3: 1238 exp/con 42.5 S4: 3078 exp/con 39 S5: 4300 exp/con 19 taken from the thread at FSP |
kiriiz
I don't mean wsx cant play itself at all Just in subjective compare of these two cabs, wlx perform better even if not coupled in stacks. Technical specifications are very nice, but listen it yourself and make conclusion |
dj-panoramix
link pleaz ?
why is S2 the same value as S3 ??
what mind rg in hr ?
eg is 2,83 ?
asaa00
http://www.freespeakerplans.com/index.php?option=com_jfusion&Itemid=64&jfile=viewtopic.php&f=7&t=216&start=30
he later corrected himself and said ATC was 435 instead of 544 |
ychole audio
Young Croc Joined: 18 January 2007 Location: United States Status: Offline Points: 625 |
More WSX reviews please!Planning to build this monsters.Thank you.
I am ZERIEL'S dad!!!
