X1 (again) |
Dom ![]() Old Croc ![]() Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
![]() ![]() ![]() ![]() ![]() Posted: 10 March 2005 at 6:19pm |
Anyone had any problems with X1's going for a walk??? We tried a prototype at a gig at the weekend and it was just wandering around all over the place, even with a decent sized full range cab ratchet strapped to the top of it. If it had had a longer speaker cable it would of probably made it's way out of the club door and f**ked off down the street.... |
roborg ![]() Registered User ![]() Joined: 05 July 2004 Location: United Kingdom Status: Offline Points: 1026 |
Hehe the angle the speakers mounted at is prolly optimal for making it
hop around, whether its on the botom or side! (couple of concrete
blocks kept a bp6 i once had
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Try some of that non-slip rubber matting they use to face walkways and things. Greg (yeah sorry to bring back those painful memories Or just build double ones so the forces help cancel each other... you've got a big van now and you're a strapping lad! |
Hobbyist2004 ![]() Registered User ![]() Joined: 06 July 2004 Status: Offline Points: 99 |
Dom, which driver was in the X1, how many watts?
Void V18-1000. At the time we were only driving it from a 700W amp as it was just providing some sub in a bar along with one of our old full range cabs. If and when we use them with the rig they'll get 1700W... Sound nice though, got a good few positive comments... |
freddyi ![]() Registered User ![]() Joined: 22 September 2004 Status: Offline Points: 936 |
can U get ladies to sit on it?
I think we'll get lots of positive comments then...
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5304 |
haha do they do it on cammand? could you teach them to set up and pack up? do the run away when the police turn up? speakers that dont wanna be confiscated!!!!!
Tom Umney ![]() Registered User ![]() ![]() Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
LOL not if they are tied down. Anyway a good way to stop speakers slipping is use large rubber feet on the bottom of them. |
gingerbiscuit69 ![]() Registered User ![]() Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
ive found a nice stack on top helps too! nothing like a few nice heavy cabs to sort it out!
biotec ![]() Old Croc ![]() Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2931 |
I found a ridiculously thick rubber matt under the main 500amp+ fuse box in a warehouse I happened to be strolling past recently. Its rated to 50,000v and is designed to prevent electricians killing themselves, although its the perfect length for a stack of 1850's, 4 wide on their sides. Only trouble is it weighs about 50kg!
Hixxie ![]() Registered User ![]() Joined: 12 October 2005 Location: United Kingdom Status: Offline Points: 13 |
@ Biotec
Check your PM inbox i might be able to help you. Hixxie |
It was so loud i nearly wee'd myself....
