  New Posts New Posts RSS Feed - X1 Build pics
X1 Build pics
Neilt001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neilt001 Quote  Post ReplyReply Direct Link To This Post Topic: X1 Build pics
    Posted: 24 February 2026 at 4:41pm
Here are some pics of my recent X1 build using the Void V18-1000 and heavy duty rubber feet on the bottom. It's powered (along with the two MHB-4818s) by a 4-channel CVR 2004 (2,000W per channel at 8ohms). Combines well with the kicks to give the full bass spectrum. I haven't used it live yet but in tests at home (in my tiny sunroom) it sounds insane. Tops are MT-121s of course (powered by CVR 1004).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neilt001 Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2026 at 4:46pm
Feel free to ask questions about the build! it's fairly straightforward and took me around 2 days for the main enclosure (plus another few weeks on and off for all the other fittings, etc).
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2026 at 5:43pm
Where is your driver acces hatch?
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2026 at 5:45pm
You forgot to make an access panel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neilt001 Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2026 at 5:00pm
I don't love access hatches so I leave one side un-glued (but use plenty of screws) so that I can replace the driver if needed, but also so I can fix any internal issues that may arise.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2026 at 10:41pm
That is a very strange way to make speakers. But Hei... What ever floats your boat 🙂
Bremen_99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremen_99 Quote  Post ReplyReply Direct Link To This Post Posted: 27 February 2026 at 11:01pm
how does the overlapping band play with the mth4818's? Does the 50-80hz or whatever sum clearly and have a good tone no weird reverberations from group delay or phase differences? Or do you have them clearly cross'ed over (x1 30-60 and 4818 60-120 or something) Do you wish you'd just built out all the same cab?
Anyway look very nice and sturdy no flexing probably sounds great.
