X1 changing the shape. |
Philipnjf
Joined: 20 April 2023 Location: Denmark Status: Offline Points: 9 |
Topic: X1 changing the shape.Posted: 05 April 2024 at 9:30am |
Hi All.
I would really like to build the X1 Sub. My problem is that the sub should be used as a single center sub. And it would use for mobile dj’ing. For looks I would like to have it under my dj decks. But the depth of the box would make it look crazy. Is there any way to make the box work, being wider, but not as deep? Hight could be as high as 85cm. It should be a matter of recalculating the ports. Keeping the same volume for the driver chamber? Best regards Philip
monkeypuzzle
Joined: 25 January 2005 Status: Online Points: 1046 |
Posted: 05 April 2024 at 10:19am |
Look in the X1 part of the forum, there are at least two threads called “letterbox x1” here you will find what you are looking for.
Philipnjf
Posted: 05 April 2024 at 11:28am |
Thank you very much
Philipnjf
Posted: 05 April 2024 at 2:41pm |
It looks like the design you mention are more tall than wide? And still very deep.
