X1 confussed about thickness of ply |
Phil
Registered User Joined: 06 May 2005 Location: United Kingdom Status: Offline Points: 6 |
Posted: 06 May 2005 at 6:29am |
Hi im phil im making some x1 cabs, ive looked at the thickness of the ply needed as it says 10 lam 18mm ply, but when i looked closely at the measurements on the plan it indicates 20mm , the thing it this would change the aangles ......help what do i do
Phil
Lasse Lukkari
Young Croc Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Are you sure you are just not confused because the front panel is recessed 20mm? Edited by Vivo |
Mal X
Registered User Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 227 |
its definately 13 laminate 18mm birch ply
Mal, how loud was that!!!!!!
tendril
Registered User Joined: 22 July 2004 Status: Offline Points: 334 |
Sort of like this? Yellow=port braces red=sides, back etc |
Tendril
A mistake is a mistake only if one learns nothing from it. |
