X1 Data and graphs with diferent drivers |
Page 123 17> |
Mircea Bartic ![]() Old Croc ![]() ![]() Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
![]() ![]() ![]() ![]() ![]() Posted: 20 March 2007 at 5:02pm |
Hi everybody
I started this thread in order to help the more beginner members of our forum build X1's loaded with diferent drivers than the original one first: enclosure data X1 is a 6th order bandpass Chamber 1 - 189 Liters tunned to 42.2 Hz Chamber 2 - 62 Liters tunned to 84.7 Hz seems that ROG has done a veery good job with this bandpass, as it models verry good with a lot of drivers. |
P audio SD-18
800W RMS 100dB/1W 129 dB / 800W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave no excursion problems do not exceed 1KW ! |
P audio C18-650EL
650W RMS 100dB/1W 128 dB / 650W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave no excursion problems do not exceed 800W ! |
P audio SD-18EL
1000W RMS 99.5dB/1W 129 dB / 1000W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave no excursion problems do not exceed 1200W ! |
P audio WN-18S
500W RMS 99.1dB/1W 126 dB / 500W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave no excursion problems do not exceed 600W ! |
P audio HP-18S
500W RMS 99.6dB/1W 127 dB / 500W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave no excursion problems do not exceed 600W ! |
P audio HP-18W
400W RMS 99.5dB/1W 126 dB / 400W graph at full power below: ![]() highpass at 35 Hz with 24 dB/octave excursion problems above 400W do not exceed 400W ! |
Drivers tested, and found not to be usable in this design, even with alterations to the ports are:
P-audio C18-600LF P-audio P-18N is looks like there are some really cheap driver that can perform in this enclosure remember, DO NOT OVERDRIVE these speakers, especially the cheaper ones because the X1 is a very brutal bandpass with uneven loading of the cone and severe unloading outside the operating range. if you need other cones simulated in this designs , just ask hope this helps ![]() Edited by Mircea Bartic - 20 March 2007 at 5:32pm |
Rog ![]() New Member ![]() Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
Nice thread my man.
Looks like your using Bass Box Pro for the sims. I didn't use that when I designed it. I'm not sure its accurate at 6th order BP. Cabs build from Bass Box Pro don't measure anything like the sims say they should.
The data used for the X1 is this, your'e close but I'm going to give you a detention for getting it wrong ha ha.
Rear Chamber (Vb1) 180 Litres
Front Chamber (Vb2) 64 Litres
Rear tuning (Fb1) 38.5Hz
Front tuning (Fb2) 73.5Hz
Bandwidth -3dB 56.7Hz
Edited by Rog Mogale - 27 March 2007 at 9:56am |
soundsystemdan ![]() Young Croc ![]() Joined: 04 April 2005 Location: Leeds UK Status: Offline Points: 716 |
I think the Void V18-1000 and PD1850 will of interest to a few.
Mike Severloh ![]() Registered User ![]() Joined: 20 March 2006 Status: Offline Points: 43 |
Hi Mircea,
it indeed does.
Personally IŽd like 2 see simus of the following drivers:
PD.186, PDN.18SB40 and PD.18BR40 BMS 18n850 (will withstand 2.5 kw of power, people say)Beyma 18G480 and 118ndw
18sound 18ND9300
B&C 18TBX100 and 18PZB100
Ciare 18.009
Selenium 18SWS1100 and 18WS600
Dayton PF460
, mainly the lightweight neodyms, and of course with cabinet parameters Rog already released.
Thanx in advance. Edited by Mike Severloh - 27 March 2007 at 12:41pm |
Mike Severloh.
The problem is Mike that unless Mircea uses the program I used to design the X1 if he uses my tunings and chamber sizes he will not get an accurate sim.
I used two programs to do the X1. I used an Akabak script I wrote that takes many things into account, like that both ports are on the floor so the end correction gives a new lower port tuning. I also used a really old and modified version of LEAP that always seems spot on with real measurements.
Mircea's plots show the F3L point in the mid 40's, my sims all give an F3L in the mid to low 30's, which is consistant with Vb1. Theres also a plot on this site somewhere of an X1 vs a Lab horn, and the plot dosen't look anything like Mircea's sims. Just found the plot.
![]() The plots were not taken in ideal condidtions as they were made at a bass shootout. So the location and room placement is reinforcing the low end quite a bit.
Rog.
Page 123 17> |
