  New Posts New Posts RSS Feed - X1 Data and graphs with diferent drivers
 Post Reply Post Reply Page  <12345 17>
skyrockhifi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyrockhifi Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2008 at 10:52am
My mates got 2 of these X1 boxes and they really do rock!
Especially when playing Leviticus - Burial
cangok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cangok Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2008 at 7:15pm
Originally posted by Mircea Bartic Mircea Bartic wrote:
if you need other cones simulated in this designs , just ask
hope this helps
is it possible to simulate the pd 1850
tnx in advanceClap
Edited by cangok - 14 March 2008 at 7:18pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2008 at 7:34pm
Ex Nexus_3
HansA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HansA Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2008 at 11:14pm
Could someone modell the Eminence Sigma 18? http://www.eminence.com/proaudio_speaker_detail.asp?web_detail_link=SIGMAPRO18A-2&speaker_size=18&SUB_CAT_ID=1
When i do it in Lineateam.dk's onlinethingie it actually turns out usable.
But what about Xmax, dips, cone quality and so forth.
Would it be of any use to throw two together with the Sigma driver?
Edited by HansA - 16 April 2008 at 11:17pm
�*�o�O�o�*�*: HansA, The FUBAR sound technician :*�*�o�O�o�*�
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2008 at 8:49pm
Has anybody modelled a PD1850 in this box or is it not compatible?
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 17 April 2008 at 8:57pm
Is it not 2 posts above you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2008 at 4:38pm
Is it? If it is then its not labeled so i wouldnt know!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2008 at 8:45pm
it's the 1850 in that post
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2008 at 8:51pm
Thanks for clarifying that Mircea Smile
Mike Severloh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Severloh Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2008 at 2:05pm
[QUOTE=the rock]Hi Every one
Do you know how well a 15" works in a X1 enclosure?
Do you know the dimension of the cabinet? If you do please can you help me. I want to build one with a 15" speaker...
/QUOTE]
Hi, I built one using an enclosure I already had. Outline was like a Community VB790:
tunnels were straight, both 38cm long
chambers were damped, being
48 l , 400 cm² tunnel
140 l, 260 cm² tunnel
Chassis: I used a cheapo, the Raveland AXX1515, which would hold  440 W "linear" till Xmax in there. Sounds - deep.
Better choices:
Ciare 15.00SW, 600 W, or even
BMS 15n840-4, 900 W, giving 124 dB/32 Hz, calculated linear, cold voice coil.
The cab is used as a drumfill infra, doing a great job between 31 and 85 Hz. Extreme hipass filter necessary for full power, of course.
Mike Severloh.
chrissnow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrissnow Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2008 at 10:15pm
I dont seem to be able to find any results for the v18-1000, a lot of people seem to like them but their doesnt appear to be a result, or I keep missing it!
If someone could provide them that would be great.
Thanks
tintin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tintin Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2008 at 5:07pm
hello I would to know if the electrovoice evx 150 work good with this cabinet, I would like make four x1, thanksTongue
