X1 Data and graphs with diferent drivers |
Post Reply | Page <12345 17> |
skyrockhifi
Registered User Joined: 21 October 2006 Status: Offline Points: 29 |
My mates got 2 of these X1 boxes and they really do rock!
Especially when playing Leviticus - Burial
cangok
Registered User Joined: 19 May 2007 Status: Offline Points: 12 |
is it possible to simulate the pd 1850 tnx in advance Edited by cangok - 14 March 2008 at 7:18pm |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
HansA
Registered User Joined: 07 March 2007 Location: Norway Status: Offline Points: 595 |
Could someone modell the Eminence Sigma 18? http://www.eminence.com/proaudio_speaker_detail.asp?web_detail_link=SIGMAPRO18A-2&speaker_size=18&SUB_CAT_ID=1
When i do it in Lineateam.dk's onlinethingie it actually turns out usable. But what about Xmax, dips, cone quality and so forth. Would it be of any use to throw two together with the Sigma driver? Edited by HansA - 16 April 2008 at 11:17pm |
�*�o�O�o�*�*: HansA, The FUBAR sound technician :*�*�o�O�o�*�
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Has anybody modelled a PD1850 in this box or is it not compatible?
Jake_Fielder
Old Croc Joined: 08 October 2007 Status: Offline Points: 4231 |
Is it not 2 posts above you?
tweeter box
Is it? If it is then its not labeled so i wouldnt know!!
Mircea Bartic
it's the 1850 in that post
tweeter box
Thanks for clarifying that Mircea
Mike Severloh
Registered User Joined: 20 March 2006 Status: Offline Points: 43 |
[QUOTE=the rock]Hi Every one
Do you know how well a 15" works in a X1 enclosure? Do you know the dimension of the cabinet? If you do please can you help me. I want to build one with a 15" speaker... /QUOTE]Hi, I built one using an enclosure I already had. Outline was like a Community VB790: tunnels were straight, both 38cm long chambers were damped, being 48 l , 400 cm² tunnel 140 l, 260 cm² tunnel Chassis: I used a cheapo, the Raveland AXX1515, which would hold 440 W "linear" till Xmax in there. Sounds - deep. Better choices: Ciare 15.00SW, 600 W, or even BMS 15n840-4, 900 W, giving 124 dB/32 Hz, calculated linear, cold voice coil. The cab is used as a drumfill infra, doing a great job between 31 and 85 Hz. Extreme hipass filter necessary for full power, of course. |
Mike Severloh.
chrissnow
Registered User Joined: 17 May 2008 Status: Offline Points: 1 |
I dont seem to be able to find any results for the v18-1000, a lot of people seem to like them but their doesnt appear to be a result, or I keep missing it!
If someone could provide them that would be great.
Thanks
tintin
Registered User Joined: 05 June 2008 Location: toul Status: Offline Points: 1 |
hello I would to know if the electrovoice evx 150 work good with this cabinet, I would like make four x1, thanks |
