X1 Delay |
Page 12> |
Soll ![]() Registered User ![]() Joined: 27 February 2005 Location: Ireland Status: Offline Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 14 June 2005 at 5:10pm |
Shore I read this here before but couldn't find when i searched just now. Any one know how much i should delay my system by to bring them in line with my X1s. Should i messure from the middle of the cone? Seems the logical place.
Thanks. |
Techno Slave
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Its not just the distance, BP6 type boxes have a high group delay at certain frequencies. Best to try to use a measurement mic and LMS with the autoalignment or use sine waves at x-over frequency to calculate the delay needed
Had a Feeling that would be the case. Can't do said tests befor the weekend. do you think I would be better off putting the High Pass Filter on my Bass bins up to 80 herts, so that they don't fase out the X1s, or will it not make that much of a diffrance? Running 4x X1 25hz to 80hz, 4x EAW Dual 15"s 40hz to 200hz
Techno Slave
tb_mike ![]() Old Croc ![]() Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
You dont normally want an overlap of systems that behave differently,especialyl in the time domain. Id start with crossover X1 LPF 80hz and dual 15"s HPF at 80hz and modify from there. |
ricky ![]() Registered User ![]() Joined: 25 October 2004 Status: Offline Points: 54 |
if you do what tb_mike says your system will play much louder. it is better to stop the low bass getting to your 15", thats why you use the x1.
soundgodwannabe ![]() Registered User ![]() ![]() Joined: 22 January 2005 Location: United States Status: Offline Points: 89 |
Make the soundman mad and I WILL press the suck button for your band.
Hobbyist2004 ![]() Registered User ![]() Joined: 06 July 2004 Status: Offline Points: 99 |
Correct me if I'm wrong, but I think I remember Rog saying there were
no delay issues with the X1 as it is not a horn. May have been in the
old forum though.
Anyone else remember? |
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Group delay, if you use a controler it is easy enough to sort out (especially when you have some measurement system)
Thanks will do as tb_mike says. Hmm Now the only problem is that The people doing the party want me to set up anouther system next to mine, 2x 1850 2x Martin w-bins mark 2, 2x Martin Philshave Midhorns, What a pain, plus they don't have the relavant exuipment to cross it over and delay it propaly. Don't really want to tell them no, I think they are going for a teknavill look.
If i stack them a bit away from my stuff...? |
Techno Slave
Okay, here is my two choices. I can either build two X1's or build one G2 subwoofers. I am wondering which would be best to use if I am using a 2/3 way crossover. They only thing that is stopping me in building the X1 is the mention of delays. I have not used them before and really am unaware as how to use a delay and why one is used. I just want something that will give me some bottom end, must be portable, and can be used indoors as well as outdoors. The G2 looks like a good way to go since I don't necessarily have to have a delay and it can be used outdoors. But at close to 150lbs, it doesn't look very appealing. A hand truck and castors are a must. Can someone shed some light on the subject of delays with these two subs? |
LunchieTey ![]() Young Croc ![]() ![]() Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
If you use x1's without delay,you're still going to get heaps of bass
anyway,I think you might be considering speakers on 15ms of LF
delay(not a huge deal) instead of th 30hz extension and 130db output!
Just build em and worry about delays when you can afford an ultradrive or something! I don't delay my 6th order cabs(similar to x1) and they still rattle roof irons with the best of them! |
Speaker addict
Tumble ![]() Registered User ![]() Joined: 09 July 2004 Location: SouthWest UK Status: Offline Points: 353 |
can you use a measurement mic with a digi drive?
Retox
Page 12> |
