  New Posts New Posts RSS Feed - x1 is it needed
x1 is it needed
Rog View Drop Down
Rogers Archive Posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Topic: x1 is it needed
    Posted: 25 October 2004 at 10:38am
Do I need x1 sub?
I have a small system that I am making; so far I have for midrange 4 cabinets with 2 12inch speakers in each 400rms per cab in the old dual fane design and then a horn on top of each cabinet for the highs. So far so good for me.
Bass wise I want to make a horn with 15inch fane driver design is off of
William Cowan’s DIY home page The Horn Sub Jr This is a 40hz bass horn
I will use just 2 off these 1 each side    nice small size
Would the system be improved if I add to it?
 X1 with void 18 1000rms driver
I have an active crossover and 31 band EQ all digital and running on 3 amps
I could get hold of a Europower EP2500 to power 2 x1s
Not the best but might work
I guess the
X1 would cross at
65khz
Horn Jr
65 to 200hz
This part is already very good for me
Dual 12s Mid
200 to3.5khz
High horns
3.5 to 18khz
Thanks for any advice I am a novice that’s having fun.
The website is very helpful.
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 11:52am
Hi Paul
One thing to note- that guy makes his design look extra great by including the Corner loading bonus TWICE!(models in 0.5pi + has a corner extension on the input window)
Bill Fitz,Djk and the rest on AA agree.
You could get an efficient 65hz-200hz horn designed for your 15" if you have t/s specs for it-that way its not TOO BIG.the HD15 is like this if you build a couple.
Note that i dont know about using BP6+horn for kicks practically,so im assuming its a good idea.
Cheers!
cowanaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowanaudio Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2004 at 3:47am
G'day Philip and Mike
I guess I'd better jump in here to dispel some rumours. If you have a look at the following three images, you will be able to compare the model for the hornsubJr as I modelled it, and without the room influence (still 1/4 space), and compare the models with the actual measured response at my listening position. You will probably come to the same conclusion I did and agree that my published model more accurately reflects the measurement. LF extension is actually better than predicted. BTW the black trace is the raw response, the other trace has been tweaked in the DCX2496 crossover with a few stages of parametric eq.
http://diy.cowanaudio.com/images/hornsubjr_response.GIF
http://diy.cowanaudio.com/images/Jr_nocnr.gif
http://diy.cowanaudio.com/images/Jr_cnr.gif
Philip, back to your question, this little sub would be worse than useless in a 1/2 space environment, when used on it's own. 4 or more cabs and you will start to get useful response. I mentioned this on my webpage to make sure no one would waste their time making just one pair.
Cheers
William Cowan
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2004 at 3:51am
Hi cowanaudio - i didnt mean to be aggressive etc-just stating what i thought to be true.
Certainly the measurement seems to agree more with the 2 corner modeling-but its too hard to say-it could be the result of slight room gain or modes.
But my point still stands,that it wont be true for all situations-
And youl still require several units to acheive desired response in 1/2pi
Cheers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowanaudio Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2004 at 4:04am
G'day Mike
I don't doubt that for one minute, I even mentioned the fact on my webpage. I doubt it would ever be flat to 36Hz, 1/2 space, with any reasonable number of boxes. It is a 40Hz, small mouth bass horn, but in my room it behaves the way I'd expect a 30Hz horn to behave.
I guess you understand that a domestic listening room is far more constrained than a 1/4 space environment? I just tryed to reflect that fact in my model. This sub was not designed for pro sound, it is a domestic bass horn, and as such works better than I could have imagined.
BTW I don't ever recall seeing a model of any of Bill F's horns? The extreme small mouths and claimed low extension of his bass horns suggests to me he is using similar reasoning. Did you try to model one?
Cheers
William Cowan
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2004 at 11:10am
Hi william
Well yes the domestic situation can well be less than 0.5pi- but how much we dont know- and walls vibrating and the lower bass passing through walls and not being contained within thin walls negates this -again we dont know how much,so id prefer to be slightly over specd than under.
Nope Bill fitzs horns are different and i havent bothered modeling one. I dont doubt his horn knowledge,Perhaps i disagree with his HT intention for some peoples uses-but for guitar type it seems quite useful
Btw the 2226 is still 'music to my ears
No plans of a super Ceiling-space basshorn with 18LW1400?
Cheers!
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2004 at 6:25pm
18LW1400 isn't that good for a horn. Föön has horns with it, but they get problems after about one year of use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2004 at 2:25am
It depends entirely on what the horn is like-id be interested to hear details on this.
They are robust drivers-its only some drivers that cant take moderate horn loading thesedays.
Cheers!
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2004 at 3:07am
It's the Föön E920HL. 2 18LW1400 in a box of 119,5cm height, 50cm width and 79,5cm depth. Hornloaded as said, horn path is 1,65m, but I can't tell throat size, mouth size or flare rate. I know from guys who are using much of them that the speakers start to make problems after some time....
Interesting story: Föön now got a subbass horn very similar to the LAB sub. It even utilises the same speakers..... but has a slightly shorter horn.
