x1 need 2 men to lift? |
Page <1234> |
mans1000 ![]() Young Croc ![]() Joined: 14 October 2004 Location: Slough Status: Offline Points: 1373 |
Lego?
Andrew ![]() Registered User ![]() Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
Meccano? Need a lot of bolts to fill all the holes. |
spaceman ![]() Registered User ![]() Joined: 26 July 2004 Location: United Kingdom Status: Offline Points: 52 |
cling wrap?
JD01 ![]() Young Croc ![]() Joined: 23 August 2004 Status: Offline Points: 819 |
Forget about plastic. We have subs made of plastic here in Germany and they don't get that much output, because much of the energy is wasted' in inflating/deflating the plastic housing. No joke, it's true...
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Actually, the thought was of a composite using plastic core material and fibre glass skins.
jerry ![]() Registered User ![]() Joined: 28 January 2005 Status: Offline Points: 5 |
Hoo Timber, I have been building boxes using a paper honeycomb material 3/4" thick and covering that with 1/8 balticbirch.Very labour intensive but my labhorns only weigh 100 lbs. Cheers
@ Jerry: I order 12! :)
Where do you get this material from Jerry? Sounds just like what I am after! How much is a sheet?
Phil B ![]() Old Croc ![]() ![]() Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2298 |
Seems this box had been " designed " around carbonfibre? It says it`s " lightweight " for a double 15" ....still 80 kilos tho` which is as much as most ply boxes ? There`s so much " teknowaffle " as well to confuse people!! http://www.qscaudio.com/products/speakers/isis/215pcm/215pcm .htm .p.
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Yeah, but that 80 kilos includes a PL230 and a PL236 plus processors so it is a significant weight loss
Yoo Guys I make this stuff myself,that is why it is labour intensive.However,a sheet of 48"by96"by1"only weighs about 13 lbs and cost me in material $30.00.I have worked with all kinds of carbonfibre,but this is not really a process that lends itself to the diy person.I can tell you how it is done and send you guys some pictures of the process,as long as you are not in a hurry,as my time is very limited. Cheers Jerry |
Page <1234> |
