x1 need 2 men to lift? |
Page <1 234 |
Phil B ![]() Old Croc ![]() ![]() Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2298 |
Missed the bit about having amps in both options! Thought when it was passive it meant non-active ? So how much would it weigh without the amp and gubbins inside....any ideas?
.p. |
Dom ![]() Old Croc ![]() Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
The 80 kilos is for the passive box, it's 104kg with the amps... |
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Sorry, my bad
Andrew ![]() Registered User ![]() Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
@jerry, I'd really appreciate some details. Perhaps you could post details about the raw materials initially so we can investigate how to buy them, and then follow up with some constructional details / photos later? |
jerry ![]() Registered User ![]() Joined: 28 January 2005 Status: Offline Points: 5 |
yoo Andrew You will need to find a source for the honeycomb core material.You will need a good compressor,to create the vacuum in the building process.I buy my core from tricell in california,but there are lots of companys making this stuf.I will post some pictures of this stuf over the weekend.I need my buddy to take them as I do not have a camera.Details of the building process will follow later. Cheers Jerry |
Yoo Andrew I have the pictures,but cant figure out how to get them online Any volenteers to put this on?E-mail me and I will forward them you and then anyone can see this.The sheets come 48/96,but this one is allready cut to the size I need. Cheers Jerry |
csijo ![]() Registered User ![]() ![]() Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 102 |
Excuse Me IF I ask something stoopid If somebody can help i will aprecciate. Thanks Jose Ortega |
Audio Fanatics, Bass lover
the driver is an audiopipe TXX-F12 and the specifications are here: I live in Venezuela and here is dificult find information for me hobby: the audio Thanks |
whitehousejamie ![]() Young Croc ![]() Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Unfortunately, that driver would be useless in a scaled down X1. It has a sensitivity of 86db, it the driver will just tear apart with anything more than low volume. |
Disco Stu ![]() Old Croc ![]() Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2486 |
Just going back a bit ive never EVER heard a decent sounding plastic box. Weight you may lose but you can most certainly hear the plastic if anyone wants to point me in the direction of a plastic box that does sound good please do. If you want the aesthetic look and durability of a plastic shell then build your box out of 15mm ply and then paint on several layers of a hardening plastic layer like they use on kayaks to make up another 3-5mm. I have seen this work quite effectively particularly in outdoor situations! Alternatively if you want maximum sound deadening then use 18mm ply and paint over that |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Page <1 234 |
