  New Posts New Posts RSS Feed - x1 need 2 men to lift?
spaceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spaceman Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 5:27pm
fiberglass prehaps? i have though about fiberglass as a material but it would take a lot of time and money to get a desired thickness plus fiber glassing stinks, bad for you, expensive and extreamly messy.
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 6:09pm
Balsa?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spaceman Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 6:16pm
papier mache
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 6:19pm
Fibre-glass (or better still carbon fibre) with a honey-comb (balsa end-grain might work too) core material. Similar to what is used by some boat-builders.
davey t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey t Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 6:21pm
HZ used to do a great BP sub made out of plastic. It was very light and compact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2005 at 10:08pm
Has anyone tried plastic flight case material, heavily braced?
Items that spring to mind are Hexagrip, FLight panel, and diamond board, but I'm not sure about the construction of all these materials.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 6:28am
They might make for suitable skin materials in a composite. Just check that it bonds to your core and make a sandwich and you're set for something very stiff and lightweight (the strength is a function of core thickness)
I am affraid that just using plastic would be very sub-optimal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 8:18am
I think Hexagrip and diamond board may already be composite boards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spaceman Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 8:42pm
tin foil?
roborg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roborg Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 9:27pm
matchsticks & balsa cement, i reckon u'd need 315,000 matches to make an 1850horn
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2005 at 10:03pm
800 paper sacks and 50kg sack of buggy wheat flour?
heres my unrealistic head http://home.earthlink.net/~buddhaboy2/HEAD.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote spaceman Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2005 at 10:06pm
preformed concrete
This page was generated in 8.031 seconds.
